Node red change not working with 1.3.5
Hello
i have
node Red 1.2.6 on Raspberry Pi
node Red 1.3.5 on a VM with Debian 10
is this possible the name of the Node did change.
As example the change node in germann
change Node bearbeiten on 1.2.6
node 'change' bearbeiten on 1.3.5
i just compared and found out the change node with a
msg.reset command is working on 1.2.6 but the same command on 1.3.5 did not
have a nice day
vinc
I’m not aware of any significant changes. Can you describe what doesn’t work and provide an example flow that demonstrates it ? Thanks
