Node-red-conrib-ewelink-cube install fails
Hi can anyone help please. I love using Node-Red to control / interogate many devices around the home because I have very little 'coding' knowledge.
I wish to use the 'ewelink-cube' nodes to interact with the Sonoff iHost Hub but the nodes continually fail to install. here is the install log;
Can anyone decipher it for me and advise corrective action? Thanks in advance....
2023-09-15T16:03:09.768Z Install : node-red-contrib-ewelink-cube 1.0.0
2023-09-15T16:09:06.157Z npm install --no-audit --no-update-notifier --save --save-prefix="~" --production node-red-contrib-ewelink-cube@1.0.0
2023-09-15T16:09:30.773Z [out]
2023-09-15T16:09:30.773Z [out] > usb@1.6.3 install /home/pi/.node-red/node_modules/usb
2023-09-15T16:09:30.773Z [out] > prebuild-install --verbose || node-gyp rebuild
2023-09-15T16:09:31.543Z [err] prebuild-install
2023-09-15T16:09:31.544Z [err]
2023-09-15T16:09:31.545Z [err] info begin Prebuild-install version 5.3.3
2023-09-15T16:09:31.558Z [err] prebuild-install
2023-09-15T16:09:31.558Z [err]  info looking for cached prebuild @ /home/pi/.npm/_prebuilds/470134-usb-v1.6.3-node-v72-linux-arm.tar.gz
2023-09-15T16:09:31.560Z [err] prebuild-install
2023-09-15T16:09:31.560Z [err]  http request GET https://github.com/tessel/node-usb/releases/download/v1.6.3/usb-v1.6.3-node-v72-linux-arm.tar.gz
2023-09-15T16:09:33.216Z [err] prebuild-install
2023-09-15T16:09:33.216Z [err]  http 404 https://github.com/tessel/node-usb/releases/download/v1.6.3/usb-v1.6.3-node-v72-linux-arm.tar.gz
2023-09-15T16:09:33.223Z [err] prebuild-install
2023-09-15T16:09:33.223Z [err]  WARN install No prebuilt binaries found (target=12.16.2 runtime=node arch=arm libc= platform=linux)
2023-09-15T16:09:35.447Z [out] make: Entering directory '/home/pi/.node-red/node_modules/usb/build'
2023-09-15T16:09:35.450Z [out]   CC(target) Release/obj.target/libusb/libusb/libusb/core.o
2023-09-15T16:09:37.198Z [out]   CC(target) Release/obj.target/libusb/libusb/libusb/descriptor.o
2023-09-15T16:09:38.629Z [out]   CC(target) Release/obj.target/libusb/libusb/libusb/hotplug.o
2023-09-15T16:09:39.121Z [out]   CC(target) Release/obj.target/libusb/libusb/libusb/io.o
2023-09-15T16:09:40.681Z [out]   CC(target) Release/obj.target/libusb/libusb/libusb/strerror.o
2023-09-15T16:09:40.982Z [out]   CC(target) Release/obj.target/libusb/libusb/libusb/sync.o
2023-09-15T16:09:41.429Z [out]   CC(target) Release/obj.target/libusb/libusb/libusb/os/poll_posix.o
2023-09-15T16:09:41.698Z [out]   CC(target) Release/obj.target/libusb/libusb/libusb/os/threads_posix.o
2023-09-15T16:09:41.919Z [out]   CC(target) Release/obj.target/libusb/libusb/libusb/os/linux_usbfs.o
2023-09-15T16:09:45.136Z [out]   CC(target) Release/obj.target/libusb/libusb/libusb/os/linux_udev.o
2023-09-15T16:09:45.306Z [err] ../libusb/libusb/os/linux_udev.c:40:10: fatal error: libudev.h: No such file or directory
2023-09-15T16:09:45.306Z [err]  #include <libudev.h>
2023-09-15T16:09:45.306Z [err]           ^~~~~~~~~~~
2023-09-15T16:09:45.306Z [err] compilation terminated.
2023-09-15T16:09:45.313Z [err] make: *** [libusb.target.mk:148: Release/obj.target/libusb/libusb/libusb/os/linux_udev.o] Error 1
2023-09-15T16:09:45.313Z [out] make: Leaving directory '/home/pi/.node-red/node_modules/usb/build'
2023-09-15T16:09:45.317Z [err] gyp
2023-09-15T16:09:45.318Z [err]
2023-09-15T16:09:45.319Z [err] ERR! build error
2023-09-15T16:09:45.321Z [err] gyp
2023-09-15T16:09:45.321Z [err]  ERR! stack Error: `make` failed with exit code: 2
2023-09-15T16:09:45.321Z [err]      at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
2023-09-15T16:09:45.321Z [err] gyp ERR!
2023-09-15T16:09:45.322Z [err]  stack     at ChildProcess.emit (events.js:310:20)
2023-09-15T16:09:45.322Z [err] gyp ERR!
2023-09-15T16:09:45.322Z [err] stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
2023-09-15T16:09:45.323Z [err] gyp
2023-09-15T16:09:45.323Z [err]  ERR! System Linux 4.19.97-v7+
2023-09-15T16:09:45.323Z [err] ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
2023-09-15T16:09:45.323Z [err] gyp ERR!
2023-09-15T16:09:45.324Z [err]  cwd /home/pi/.node-red/node_modules/usb
2023-09-15T16:09:45.324Z [err] gyp ERR! node -v
2023-09-15T16:09:45.324Z [err]  v12.16.2
2023-09-15T16:09:45.324Z [err] ERR! node-gyp -v v5.1.0
2023-09-15T16:09:45.325Z [err] not ok
2023-09-15T16:09:47.780Z [err] npm
2023-09-15T16:09:47.781Z [err]  WARN node-red-contrib-ui-led@0.3.1 requires a peer of node-red-dashboard@2.14.x but none is installed. You must install peer dependencies yourself.
2023-09-15T16:09:47.782Z [err] npm
2023-09-15T16:09:47.782Z [err]  WARN optional SKIPPING OPTIONAL DEPENDENCY: usb@1.6.3 (node_modules/usb):
2023-09-15T16:09:47.782Z [err]  SKIPPING OPTIONAL DEPENDENCY: usb@1.6.3 install: `prebuild-install --verbose || node-gyp rebuild`
2023-09-15T16:09:47.782Z [err] npm WARN
2023-09-15T16:09:47.782Z [err]  optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
2023-09-15T16:09:47.783Z [err]
2023-09-15T16:09:47.787Z [out] + node-red-contrib-ewelink-cube@1.0.0
2023-09-15T16:09:47.787Z [out] updated 1 package in 39.468s
2023-09-15T16:09:49.743Z [out]
2023-09-15T16:09:49.743Z [out] 22 packages are looking for funding
2023-09-15T16:09:49.743Z [out]   run `npm fund` for details
2023-09-15T16:09:49.820Z rc=0
2023-09-15T16:13:14.841Z Install : node-red-contrib-ewelink-cube 1.0.0
2023-09-15T16:19:11.272Z npm install --no-audit --no-update-notifier --save --save-prefix="~" --production node-red-contrib-ewelink-cube@1.0.0
2023-09-15T16:19:39.993Z [out]
2023-09-15T16:19:39.993Z [out] > usb@1.6.3 install /home/pi/.node-red/node_modules/usb
2023-09-15T16:19:39.993Z [out] > prebuild-install --verbose || node-gyp rebuild
2023-09-15T16:19:40.846Z [err] prebuild-install
2023-09-15T16:19:40.848Z [err]
2023-09-15T16:19:40.849Z [err] info begin Prebuild-install version 5.3.3
2023-09-15T16:19:40.862Z [err] prebuild-install
2023-09-15T16:19:40.862Z [err]  info looking for cached prebuild @ /home/pi/.npm/_prebuilds/470134-usb-v1.6.3-node-v72-linux-arm.tar.gz
2023-09-15T16:19:40.865Z [err] prebuild-install
2023-09-15T16:19:40.866Z [err]  http request GET https://github.com/tessel/node-usb/releases/download/v1.6.3/usb-v1.6.3-node-v72-linux-arm.tar.gz
2023-09-15T16:19:41.443Z [err] prebuild-install
2023-09-15T16:19:41.444Z [err]  http 404 https://github.com/tessel/node-usb/releases/download/v1.6.3/usb-v1.6.3-node-v72-linux-arm.tar.gz
2023-09-15T16:19:41.450Z [err] prebuild-install
2023-09-15T16:19:41.451Z [err]  WARN install No prebuilt binaries found (target=12.16.2 runtime=node arch=arm libc= platform=linux)
2023-09-15T16:19:44.185Z [out] make: Entering directory '/home/pi/.node-red/node_modules/usb/build'
2023-09-15T16:19:44.193Z [out]   CC(target) Release/obj.target/libusb/libusb/libusb/core.o
2023-09-15T16:19:48.608Z [out]   CC(target) Release/obj.target/libusb/libusb/libusb/descriptor.o
2023-09-15T16:19:50.108Z [out]   CC(target) Release/obj.target/libusb/libusb/libusb/hotplug.o
2023-09-15T16:19:50.644Z [out]   CC(target) Release/obj.target/libusb/libusb/libusb/io.o
2023-09-15T16:19:52.227Z [out]   CC(target) Release/obj.target/libusb/libusb/libusb/strerror.o
2023-09-15T16:19:52.530Z [out]   CC(target) Release/obj.target/libusb/libusb/libusb/sync.o
2023-09-15T16:19:53.027Z [out]   CC(target) Release/obj.target/libusb/libusb/libusb/os/poll_posix.o
2023-09-15T16:19:53.306Z [out]   CC(target) Release/obj.target/libusb/libusb/libusb/os/threads_posix.o
2023-09-15T16:19:53.536Z [out]   CC(target) Release/obj.target/libusb/libusb/libusb/os/linux_usbfs.o
2023-09-15T16:19:56.836Z [out]   CC(target) Release/obj.target/libusb/libusb/libusb/os/linux_udev.o
2023-09-15T16:19:57.015Z [err] ../libusb/libusb/os/linux_udev.c:40:10: fatal error: libudev.h: No such file or directory
2023-09-15T16:19:57.015Z [err]  #include <libudev.h>
2023-09-15T16:19:57.015Z [err]           ^~~~~~~~~~~
2023-09-15T16:19:57.015Z [err] compilation terminated.
2023-09-15T16:19:57.022Z [err] make: *** [libusb.target.mk:148: Release/obj.target/libusb/libusb/libusb/os/linux_udev.o] Error 1
2023-09-15T16:19:57.023Z [out] make: Leaving directory '/home/pi/.node-red/node_modules/usb/build'
2023-09-15T16:19:57.027Z [err] gyp
2023-09-15T16:19:57.028Z [err]
2023-09-15T16:19:57.028Z [err] ERR! build error
2023-09-15T16:19:57.030Z [err] gyp
2023-09-15T16:19:57.030Z [err]  ERR! stack Error: `make` failed with exit code: 2
2023-09-15T16:19:57.030Z [err] gyp ERR!
2023-09-15T16:19:57.031Z [err] stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
2023-09-15T16:19:57.031Z [err] gyp
2023-09-15T16:19:57.031Z [err] ERR! stack
2023-09-15T16:19:57.031Z [err]      at ChildProcess.emit (events.js:310:20)
2023-09-15T16:19:57.031Z [err] gyp ERR!
2023-09-15T16:19:57.031Z [err]  stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
2023-09-15T16:19:57.032Z [err] gyp
2023-09-15T16:19:57.032Z [err] ERR! System Linux 4.19.97-v7+
2023-09-15T16:19:57.033Z [err]  ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
2023-09-15T16:19:57.033Z [err] gyp ERR!
2023-09-15T16:19:57.033Z [err]  cwd /home/pi/.node-red/node_modules/usb
2023-09-15T16:19:57.033Z [err]  ERR! node -v
2023-09-15T16:19:57.033Z [err]  v12.16.2
2023-09-15T16:19:57.034Z [err]  node-gyp -v v5.1.0
2023-09-15T16:19:57.034Z [err] gyp
2023-09-15T16:19:57.034Z [err]  ERR! not ok
2023-09-15T16:19:59.604Z [err] npm
2023-09-15T16:19:59.605Z [err]  WARN node-red-contrib-ui-led@0.3.1 requires a peer of node-red-dashboard@2.14.x but none is installed. You must install peer dependencies yourself.
2023-09-15T16:19:59.605Z [err] npm
2023-09-15T16:19:59.606Z [err]  WARN optional SKIPPING OPTIONAL DEPENDENCY: usb@1.6.3 (node_modules/usb):
2023-09-15T16:19:59.606Z [err] npm WARN optional
2023-09-15T16:19:59.606Z [err]  SKIPPING OPTIONAL DEPENDENCY: usb@1.6.3 install: `prebuild-install --verbose || node-gyp rebuild`
2023-09-15T16:19:59.606Z [err]  optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
2023-09-15T16:19:59.607Z [err]
2023-09-15T16:19:59.610Z [out] + node-red-contrib-ewelink-cube@1.0.0
2023-09-15T16:19:59.610Z [out] updated 1 package in 45.327s
2023-09-15T16:20:01.615Z [out]
2023-09-15T16:20:01.615Z [out] 22 packages are looking for funding
2023-09-15T16:20:01.615Z [out]   run `npm fund` for details
2023-09-15T16:20:01.662Z rc=0
2023-09-15T16:30:32.467Z Install : node-red-contrib-ewelink-cube 1.0.0
2023-09-15T16:36:28.784Z npm install --no-audit --no-update-notifier --save --save-prefix="~" --production node-red-contrib-ewelink-cube@1.0.0
2023-09-15T16:36:53.441Z [out]
2023-09-15T16:36:53.441Z [out] > usb@1.6.3 install /home/pi/.node-red/node_modules/usb
2023-09-15T16:36:53.441Z [out] > prebuild-install --verbose || node-gyp rebuild
2023-09-15T16:36:54.203Z [err] prebuild-install
2023-09-15T16:36:54.205Z [err]
2023-09-15T16:36:54.205Z [err] info begin Prebuild-install version 5.3.3
2023-09-15T16:36:54.218Z [err] prebuild-install
2023-09-15T16:36:54.219Z [err]  info
2023-09-15T16:36:54.219Z [err] looking for cached prebuild @ /home/pi/.npm/_prebuilds/470134-usb-v1.6.3-node-v72-linux-arm.tar.gz
2023-09-15T16:36:54.220Z [err] prebuild-install
2023-09-15T16:36:54.220Z [err]  http
2023-09-15T16:36:54.220Z [err] request GET https://github.com/tessel/node-usb/releases/download/v1.6.3/usb-v1.6.3-node-v72-linux-arm.tar.gz
2023-09-15T16:36:54.830Z [err] prebuild-install
2023-09-15T16:36:54.831Z [err]  http 404 https://github.com/tessel/node-usb/releases/download/v1.6.3/usb-v1.6.3-node-v72-linux-arm.tar.gz
2023-09-15T16:36:54.838Z [err] prebuild-install
2023-09-15T16:36:54.838Z [err]  WARN install No prebuilt binaries found (target=12.16.2 runtime=node arch=arm libc= platform=linux)
2023-09-15T16:36:57.030Z [out] make: Entering directory '/home/pi/.node-red/node_modules/usb/build'
2023-09-15T16:36:57.043Z [out]   CC(target) Release/obj.target/libusb/libusb/libusb/core.o
2023-09-15T16:36:58.768Z [out]   CC(target) Release/obj.target/libusb/libusb/libusb/descriptor.o
2023-09-15T16:37:00.239Z [out]   CC(target) Release/obj.target/libusb/libusb/libusb/hotplug.o
2023-09-15T16:37:00.725Z [out]   CC(target) Release/obj.target/libusb/libusb/libusb/io.o
2023-09-15T16:37:02.348Z [out]   CC(target) Release/obj.target/libusb/libusb/libusb/strerror.o
2023-09-15T16:37:02.655Z [out]   CC(target) Release/obj.target/libusb/libusb/libusb/sync.o
2023-09-15T16:37:03.097Z [out]   CC(target) Release/obj.target/libusb/libusb/libusb/os/poll_posix.o
2023-09-15T16:37:03.368Z [out]   CC(target) Release/obj.target/libusb/libusb/libusb/os/threads_posix.o
2023-09-15T16:37:03.588Z [out]   CC(target) Release/obj.target/libusb/libusb/libusb/os/linux_usbfs.o
2023-09-15T16:37:06.817Z [out]   CC(target) Release/obj.target/libusb/libusb/libusb/os/linux_udev.o
2023-09-15T16:37:06.983Z [err] ../libusb/libusb/os/linux_udev.c:40:10: fatal error: libudev.h: No such file or directory
2023-09-15T16:37:06.983Z [err]  #include <libudev.h>
2023-09-15T16:37:06.983Z [err]           ^~~~~~~~~~~
2023-09-15T16:37:06.983Z [err] compilation terminated.
2023-09-15T16:37:06.990Z [err] make: *** [libusb.target.mk:148: Release/obj.target/libusb/libusb/libusb/os/linux_udev.o] Error 1
2023-09-15T16:37:06.991Z [out] make: Leaving directory '/home/pi/.node-red/node_modules/usb/build'
2023-09-15T16:37:06.995Z [err] gyp
2023-09-15T16:37:06.996Z [err]
2023-09-15T16:37:06.996Z [err] ERR! build error
2023-09-15T16:37:06.998Z [err] gyp
2023-09-15T16:37:06.998Z [err]  ERR! stack
2023-09-15T16:37:06.998Z [err]  Error: `make` failed with exit code: 2
2023-09-15T16:37:06.999Z [err]      at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
2023-09-15T16:37:06.999Z [err] gyp
2023-09-15T16:37:06.999Z [err]  ERR!
2023-09-15T16:37:06.999Z [err] stack     at ChildProcess.emit (events.js:310:20)
2023-09-15T16:37:06.999Z [err] ERR! stack
2023-09-15T16:37:06.999Z [err]      at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
2023-09-15T16:37:07.000Z [err] gyp
2023-09-15T16:37:07.000Z [err]  ERR! System Linux 4.19.97-v7+
2023-09-15T16:37:07.000Z [err] ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
2023-09-15T16:37:07.001Z [err] gyp
2023-09-15T16:37:07.001Z [err]  ERR!
2023-09-15T16:37:07.001Z [err] cwd /home/pi/.node-red/node_modules/usb
2023-09-15T16:37:07.001Z [err] ERR! node -v
2023-09-15T16:37:07.001Z [err]  v12.16.2
2023-09-15T16:37:07.001Z [err] node-gyp -v v5.1.0
2023-09-15T16:37:07.002Z [err] gyp ERR!
2023-09-15T16:37:07.002Z [err]  not ok
2023-09-15T16:37:09.553Z [err] npm WARN node-red-contrib-ui-led@0.3.1 requires a peer of node-red-dashboard@2.14.x but none is installed. You must install peer dependencies yourself.
2023-09-15T16:37:09.553Z [err] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: usb@1.6.3 (node_modules/usb):
2023-09-15T16:37:09.553Z [err] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: usb@1.6.3 install: `prebuild-install --verbose || node-gyp rebuild`
2023-09-15T16:37:09.553Z [err] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
2023-09-15T16:37:09.553Z [out] + node-red-contrib-ewelink-cube@1.0.0
2023-09-15T16:37:09.553Z [out] updated 1 package in 38.713s
2023-09-15T16:37:11.503Z [out]
2023-09-15T16:37:11.503Z [out] 22 packages are looking for funding
2023-09-15T16:37:11.503Z [out]   run `npm fund` for details
2023-09-15T16:37:11.588Z rc=0
2023-09-15T16:37:44.080Z Install : node-red-contrib-ewelink-cube 1.0.0
2023-09-15T16:43:40.397Z npm install --no-audit --no-update-notifier --save --save-prefix="~" --production node-red-contrib-ewelink-cube@1.0.0
2023-09-15T16:44:03.877Z [out]
2023-09-15T16:44:03.877Z [out] > usb@1.6.3 install /home/pi/.node-red/node_modules/usb
2023-09-15T16:44:03.877Z [out] > prebuild-install --verbose || node-gyp rebuild
2023-09-15T16:44:04.641Z [err] prebuild-install
2023-09-15T16:44:04.643Z [err]
2023-09-15T16:44:04.643Z [err] info begin Prebuild-install version 5.3.3
2023-09-15T16:44:04.656Z [err] prebuild-install
2023-09-15T16:44:04.656Z [err]  info
2023-09-15T16:44:04.657Z [err] looking for cached prebuild @ /home/pi/.npm/_prebuilds/470134-usb-v1.6.3-node-v72-linux-arm.tar.gz
2023-09-15T16:44:04.658Z [err] prebuild-install
2023-09-15T16:44:04.658Z [err]  http
2023-09-15T16:44:04.658Z [err] request GET https://github.com/tessel/node-usb/releases/download/v1.6.3/usb-v1.6.3-node-v72-linux-arm.tar.gz
2023-09-15T16:44:05.246Z [err] prebuild-install
2023-09-15T16:44:05.247Z [err]  http 404 https://github.com/tessel/node-usb/releases/download/v1.6.3/usb-v1.6.3-node-v72-linux-arm.tar.gz
2023-09-15T16:44:05.253Z [err] prebuild-install
2023-09-15T16:44:05.254Z [err]  WARN install No prebuilt binaries found (target=12.16.2 runtime=node arch=arm libc= platform=linux)
2023-09-15T16:44:07.488Z [out] make: Entering directory '/home/pi/.node-red/node_modules/usb/build'
2023-09-15T16:44:07.490Z [out]   CC(target) Release/obj.target/libusb/libusb/libusb/core.o
2023-09-15T16:44:09.268Z [out]   CC(target) Release/obj.target/libusb/libusb/libusb/descriptor.o
2023-09-15T16:44:10.710Z [out]   CC(target) Release/obj.target/libusb/libusb/libusb/hotplug.o
2023-09-15T16:44:11.206Z [out]   CC(target) Release/obj.target/libusb/libusb/libusb/io.o
2023-09-15T16:44:12.766Z [out]   CC(target) Release/obj.target/libusb/libusb/libusb/strerror.o
2023-09-15T16:44:13.064Z [out]   CC(target) Release/obj.target/libusb/libusb/libusb/sync.o
2023-09-15T16:44:13.552Z [out]   CC(target) Release/obj.target/libusb/libusb/libusb/os/poll_posix.o
2023-09-15T16:44:13.819Z [out]   CC(target) Release/obj.target/libusb/libusb/libusb/os/threads_posix.o
2023-09-15T16:44:14.039Z [out]   CC(target) Release/obj.target/libusb/libusb/libusb/os/linux_usbfs.o
2023-09-15T16:44:17.277Z [out]   CC(target) Release/obj.target/libusb/libusb/libusb/os/linux_udev.o
2023-09-15T16:44:17.442Z [err] ../libusb/libusb/os/linux_udev.c:40:10: fatal error: libudev.h: No such file or directory
2023-09-15T16:44:17.442Z [err]  #include <libudev.h>
2023-09-15T16:44:17.442Z [err]           ^~~~~~~~~~~
2023-09-15T16:44:17.442Z [err] compilation terminated.
2023-09-15T16:44:17.450Z [err] make: *** [libusb.target.mk:148: Release/obj.target/libusb/libusb/libusb/os/linux_udev.o] Error 1
2023-09-15T16:44:17.450Z [out] make: Leaving directory '/home/pi/.node-red/node_modules/usb/build'
2023-09-15T16:44:17.454Z [err] gyp
2023-09-15T16:44:17.455Z [err]
2023-09-15T16:44:17.455Z [err] ERR! build error
2023-09-15T16:44:17.457Z [err] gyp
2023-09-15T16:44:17.458Z [err]  ERR! stack
2023-09-15T16:44:17.458Z [err]  Error: `make` failed with exit code: 2
2023-09-15T16:44:17.458Z [err] gyp
2023-09-15T16:44:17.458Z [err] stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
2023-09-15T16:44:17.458Z [err] stack     at ChildProcess.emit (events.js:310:20)
2023-09-15T16:44:17.459Z [err] gyp
2023-09-15T16:44:17.459Z [err] ERR!
2023-09-15T16:44:17.459Z [err] stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
2023-09-15T16:44:17.460Z [err]  ERR! System
2023-09-15T16:44:17.460Z [err]  Linux 4.19.97-v7+
2023-09-15T16:44:17.460Z [err] gyp
2023-09-15T16:44:17.460Z [err]  ERR! command
2023-09-15T16:44:17.460Z [err]  "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
2023-09-15T16:44:17.460Z [err] ERR! cwd
2023-09-15T16:44:17.460Z [err]  /home/pi/.node-red/node_modules/usb
2023-09-15T16:44:17.461Z [err] gyp ERR!
2023-09-15T16:44:17.461Z [err]  node -v v12.16.2
2023-09-15T16:44:17.461Z [err]  ERR!
2023-09-15T16:44:17.461Z [err]  node-gyp -v v5.1.0
2023-09-15T16:44:17.461Z [err] not ok
2023-09-15T16:44:20.086Z [err] npm
2023-09-15T16:44:20.086Z [err]  WARN node-red-contrib-ui-led@0.3.1 requires a peer of node-red-dashboard@2.14.x but none is installed. You must install peer dependencies yourself.
2023-09-15T16:44:20.087Z [err] npm
2023-09-15T16:44:20.088Z [err]  WARN optional SKIPPING OPTIONAL DEPENDENCY: usb@1.6.3 (node_modules/usb):
2023-09-15T16:44:20.088Z [err] npm WARN optional
2023-09-15T16:44:20.088Z [err]  SKIPPING OPTIONAL DEPENDENCY: usb@1.6.3 install: `prebuild-install --verbose || node-gyp rebuild`
2023-09-15T16:44:20.088Z [err] WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
2023-09-15T16:44:20.090Z [err]
2023-09-15T16:44:20.093Z [out] + node-red-contrib-ewelink-cube@1.0.0
2023-09-15T16:44:20.093Z [out] updated 1 package in 37.547s
2023-09-15T16:44:21.963Z [out]
2023-09-15T16:44:21.963Z [out] 22 packages are looking for funding
2023-09-15T16:44:21.963Z [out]   run `npm fund` for details
2023-09-15T16:44:22.002Z rc=0
According to that, it installed.
The other errors are due to NPM trying to update/build other packages - in particular:
which if you look at that link, does not exist. So it tries (and fails) to build it for you
Reading further down:
Looking at the clues so far, it seems your PI is OLD and quite a long way out of date
node-gyp is currently on V9.x
Node 12 is End Of Life some time ago
That kernel is from 2018
In short - you device needs some proper TLC (and a whole bunch of updates)
Start there is my suggestion.
Steve thank you so much for your response I really appreciate it. I'll do some research regarding the issues you have raised and see if I can achieve a more successful outcome. I'll report back here as to my progress. Very grateful, Jon
