Node-red-contrib-fritz and FritzBox 7490: Error on using service / action
I need your help. Using node-red-contrib-fritz NodeRed 2.2.2, FB 7490 with FritzOS 07.29. Trying to make a call "urn:dslforum-org:service:X_VoIP:1" -> "X_AVM-DE_DialNumber". While this works well from an ESP8266 unit (so configuration on FB is fine) I run into consistent errors ("Action failed with error: TypeError [ERR_INVALID_CHAR]: Invalid character in header content ["authorization"]").
Same happens on other services (e.g. GetDeviceInfo).
Does anybody have an idea what the problem might be?
BTW: The module pallette shows a warning "Assertion failed".
I had the same error a long time ago - here is the solution:
https://discourse.nodered.org/t/payload-object-with-in-the-name-does-not-work/16560
