A while back, I wrote that the document on this contrib-node was challenging aka inexistant.
I found some example and managed my way with that.
Here is an example of hset/hget/hgetall :
[{"id":"abbacc5e71e5252c","type":"inject","z":"3af82246.3634ae","name":"","props":[{"p":"topic","v":"[ \"myhash\", \"mykey\", true ]","vt":"json"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":1730,"y":80,"wires":[["74209ee548eb8dd5"]]},{"id":"74209ee548eb8dd5","type":"redis-command","z":"3af82246.3634ae","server":"fe8691ad5774eda3","command":"HSET","name":"","topic":"","params":"[]","paramsType":"json","payloadType":"json","block":false,"x":1890,"y":80,"wires":[["4851bf2cf704eec6"]]},{"id":"4851bf2cf704eec6","type":"debug","z":"3af82246.3634ae","name":"debug 22","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":2080,"y":80,"wires":[]},{"id":"3c819e6a54297301","type":"inject","z":"3af82246.3634ae","name":"","props":[{"p":"topic","v":"[ \"myhash\", \"mykey\" ]","vt":"json"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":1730,"y":140,"wires":[["e10ad78bdf567654"]]},{"id":"e10ad78bdf567654","type":"redis-command","z":"3af82246.3634ae","server":"fe8691ad5774eda3","command":"HGET","name":"","topic":"","params":"[]","paramsType":"json","payloadType":"json","block":false,"x":1890,"y":140,"wires":[["ed94050fd79c9e9a"]]},{"id":"ed94050fd79c9e9a","type":"debug","z":"3af82246.3634ae","name":"debug 23","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":2080,"y":140,"wires":[]},{"id":"ee8c95ae8fe5e704","type":"inject","z":"3af82246.3634ae","name":"","props":[{"p":"topic","v":"[ \"myhash\" ]","vt":"json"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":1730,"y":200,"wires":[["a59acda2ab35267f"]]},{"id":"a59acda2ab35267f","type":"redis-command","z":"3af82246.3634ae","server":"fe8691ad5774eda3","command":"HGETALL","name":"","topic":"","params":"[]","paramsType":"json","payloadType":"json","block":false,"x":1900,"y":200,"wires":[["a8cd9db0270c1350"]]},{"id":"a8cd9db0270c1350","type":"debug","z":"3af82246.3634ae","name":"debug 24","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":2080,"y":200,"wires":[]},{"id":"fe8691ad5774eda3","type":"redis-config","name":"Redis","options":"redis:6379","cluster":false,"optionsType":"str"},{"id":"6c370e19956e05d4","type":"global-config","env":[],"modules":{"node-red-contrib-redis":"1.4.0"}}]
