node-red-contrib-static-markdown seems to provide the exact functionality I need but I am facing a little issue:
I have cloned the github repository:
so that I can test that the markdown in the example folder docs/test-md-library is properly rendered.
This seems to be the case for the index.md but not for the test.md in same folder.
So this is what I get when navigating to test.md:
same error copy pasted as text:
TypeError: Cannot read property 'attrJoin' of undefined
at Object.exports.addAttrs (/data/node_modules/@gerhobbelt/markdown-it-attrs/utils.js:105:13)
at Object.transform (/data/node_modules/@gerhobbelt/markdown-it-attrs/patterns.js:131:15)
at Array.curlyAttrs (/data/node_modules/@gerhobbelt/markdown-it-attrs/index.js:30:19)
at Core.process (/data/node_modules/markdown-it/lib/parser_core.js:51:13)
at MarkdownIt.parse (/data/node_modules/markdown-it/lib/index.js:523:13)
at MarkdownIt.render (/data/node_modules/markdown-it/lib/index.js:543:36)
at /data/node_modules/node-red-contrib-static-markdown/nodes/lib/serveMarkdown.js:213:39
at /data/node_modules/graceful-fs/graceful-fs.js:123:16
at FSReqWrap.readFileAfterClose [as oncomplete] (internal/fs/read_file_context.js:53:3)
Note that it seems to be working fine for index.md. So when navigating to http://127.0.0.1:1880/md or http://127.0.0.1:1880/md/index.md : I am seeing the following page:
