Hi together,
I have installed the node-red-contrib-tahoma v3.0.0.beta5. The communication with the box works and I can read values from the sun sensor.
Using syntax {"action":"customPosition","position":25} I can move the shutters and blinds.
But I cannot tilt the blinds - using syntax {"action":"customRotation","orientation":50}.
Is there a bug here, or how did you solve it?
Thanks a lot
Somfy Tahoma for Node-RED Informations:
Node tahoma
This node accepts an object as input. The following properties will be parsed:
| Property | Type | Required? | Description |
action |
enum (see below) | Yes | The action to perform |
position |
int (0-100) | No | The position you want to set your blinds/door to |
rotation |
int (0-100) | No | The rotation you want to set your blinds to |
lowspeed |
boolean | No | Should the action be triggered in low-speed mode? |
Currently, only a few commands are understood by this node. The possible values for the action property are:
open: This will open the device (door, blind...)close: This will close the devicestop: This will stop all running actionscustomPosition: This will set the device to a custom position. The position is passed using thepositionproperty, which is required in this mode.customRotation: This will set the device (blinds) to a custom rotation. The rotation is passed using theorientationproperty, which is required in this mode.
