node-RED crashing with 'Invalid Websocket Frame'
I'm running a flow using node-red-contrib-ocpp, and have had a few node-RED crashes over the past week when that flow is running.
In the logfile I see it's linked to a 'Invalid WebSocket frame: RSV1 must be clear' error.
I've googled the error, but not found an answer that I can comprehend!!
I believe that the websocket is managed from within the ocpp node (I'm not using a websocket node).
Is there anything I can do to catch the error, other than raise a git issue?
Any thoughts or advice @bnystrom
May 22 14:33:28 homeserver Node-RED[2388]: 2025-05-22 14:33:28.945 FATAL  Logger               Unhandled error detected: Invalid WebSocket frame: RSV1 must be clear
May 22 14:33:28 homeserver Node-RED[2388]:   at Receiver.getInfo (/home/me/.node-red/node_modules/express-ws/node_modules/ws/lib/receiver.js:184:14)
May 22 14:33:28 homeserver Node-RED[2388]:   at Receiver.startLoop (/home/me/.node-red/node_modules/express-ws/node_modules/ws/lib/receiver.js:131:22)
May 22 14:33:28 homeserver Node-RED[2388]:   at Receiver._write (/home/me/.node-red/node_modules/express-ws/node_modules/ws/lib/receiver.js:78:10)
May 22 14:33:28 homeserver Node-RED[2388]:   at writeOrBuffer (node:internal/streams/writable:572:12)
May 22 14:33:28 homeserver Node-RED[2388]:   at _write (node:internal/streams/writable:501:10)
May 22 14:33:28 homeserver Node-RED[2388]:   at Writable.write (node:internal/streams/writable:510:10)
May 22 14:33:28 homeserver Node-RED[2388]:   at Socket.socketOnData (/home/me/.node-red/node_modules/express-ws/node_modules/ws/lib/websocket.js:1164:35)
May 22 14:33:28 homeserver Node-RED[2388]:   at Socket.emit (node:events:524:28)
May 22 14:33:28 homeserver Node-RED[2388]:   at addChunk (node:internal/streams/readable:561:12)
May 22 14:33:28 homeserver Node-RED[2388]:   at readableAddChunkPushByteMode (node:internal/streams/readable:512:3)
May 22 14:33:28 homeserver Node-RED[2388]: 22 May 14:33:28 - [red] Uncaught Exception:
May 22 14:33:28 homeserver Node-RED[2388]: 22 May 14:33:28 - [error] RangeError: Invalid WebSocket frame: RSV1 must be clear
May 22 14:33:29 homeserver systemd[1]: nodered.service: Main process exited, code=exited, status=1/FAILURE
May 22 14:33:29 homeserver systemd[1]: nodered.service: Failed with result 'exit-code'.
May 22 14:33:29 homeserver systemd[1]: nodered.service: Consumed 3h 5min 2.933s CPU time.
While a bit esoteric, the error explanation seems clear.
This from Brave's Leo AI:
Invalid WebSocket Frame
An error "Invalid WebSocket frame: RSV1 must be clear" typically indicates that the RSV1 bit in the WebSocket frame header is set to 1, which is not allowed unless an extension has been negotiated that defines a meaning for a non-zero value of RSV1. According to the WebSocket protocol specification, RSV1, RSV2, and RSV3 bits must be 0 unless an extension is negotiated that defines meanings for non-zero values. If a nonzero value is received and none of the negotiated extensions defines the meaning of such a nonzero value, the receiving endpoint must fail the WebSocket connection
This error can occur in various WebSocket implementations, such as the ws library for Node.js, where it is reported as an issue in version 3.0.0
To resolve this issue, ensure that any extensions that define the meaning of non-zero RSV bits are properly negotiated and that the WebSocket frames adhere to the protocol specification
To me, that means that yes, you will have to report it to the node's author. At the very least, the node should catch the error so that Node-RED doesn't crash.
Thanks Julian, issue raised Crashing node-RED - Invalid Web Socket Frame · Issue #95 · argonne-vci/node-red-contrib-ocpp · GitHub
Now lets see if they know how to fix it! :smiley:
