Hi all!
I'm running node-red dockerized and i want to use a USB camera. The host detect the USB camera correctly but i have node-red inside a docker container and there comes the problem. I cannot use it inside the container neither on node-red.
Anyone?
Thanks !
you will need to give your container the correct permissions - google is your friend.
The container is running with sudo user and i've mapped the devices so the container could "see" the usb camera attached on the host.
Hi all! I have node-red dockerized inside a vm working properlly and now i want to add some face or object recognition. Everthing goes well until i add a USB camera inside the docker container.
The host detects the camera perfectly but i cannot make it work inside the container and i have the conclussion that the container needs the FSWEBCAM module to make it work.
So, the problems begins...
The official node-red image is alpine, very very light, so whenever i want to install some library is a little tricky.
Anyone experienced with this?.
Is it possible to make work the usb camera inside the container?
Thanks!!
the docker project on github also include a custom builder that includes a debian based version if you want to build one yourself that may be more flexible for you needs. GitHub - node-red/node-red-docker: Repository for all things Node-RED and Docker related
