Node-Red flows keep showing disconnected at times
I'm using HA on a Nuc PC under Proxmox...
I've installed Node Red and it seems tobe working, but the nodes I have, after a short time, stop working and show "disconnected.
Do these logs from HA "Supervisor" look ok?
23-10-13 19:09:09 INFO (MainThread) [supervisor.api.proxy] WebSocket access from a0d7b954_nodered
23-10-13 19:09:09 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request running
23-10-13 19:09:09 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API error: Received message 8:0 is not WSMsgType.TEXT
23-10-13 19:09:09 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API connection is closed
23-10-13 19:09:13 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize
23-10-13 19:09:13 INFO (MainThread) [supervisor.api.proxy] WebSocket access from a0d7b954_nodered
Node Red Logs:
13 Oct 19:09:13 - [info] [server:Home Assistant] Connecting to http: //supervisor/core
13 Oct 19:09:13 - [info] [server:Home Assistant] Connected to http: //supervisor/core
13 Oct 19:10:18 - [info] [server:Home Assistant] Connection closed to http://supervisor/core
13 Oct 19:10:23 - [info] [server:Home Assistant] Connecting to http ://supervisor/core
13 Oct 19:10:23 - [info] [server:Home Assistant] Connected to http: //supervisor/core
13 Oct 19:15:58 - [info] [server:Home Assistant] Connection closed to http: //supervisor/core
13 Oct 19:16:03 - [info] [server:Home Assistant] Connecting to http: //supervisor/core
13 Oct 19:16:03 - [info] [server:Home Assistant] Connected to http: //supervisor/core
Hi @Dozer - hope your well!
I am afraid my answer to this will be to seek support from the Home Assistant community.
Most here do not use Home Assistant - most on these forums use Node RED Bare-metal, and therefore won’t have much knowledge in why Home Assistant disconnects.
Thats not to say the problem is not with Proxmox - but so many layers are before Node RED here - so I would start with the source of the error - Home Assistant
