Node red in docker
I have loaded Node-Red onto my QNAP NAS using container and hence docker. When I open node red I do not see the option to “ Manage Pallett” . Anyone know how to resolve this. Thanks
look at the start up logs, but for manage pallete to be there you need to have npm installed so I’d guess it is that
using the terminal and npm -v it tells me I have version 2.14.20. So I am none the wiser.
Peter
and the node-red start up logs?
Also what version of Node-RED and nodejs are you using?
3 Feb 18:48:51 - [info] Node-RED version: v0.13.4
3 Feb 18:48:51 - [info] Node.js version: v4.4.1
3 Feb 18:48:51 - [info] Linux 4.2.8 x64 LE
3 Feb 18:48:51 - [info] Loading palette nodes
3 Feb 18:49:07 - [warn] ------------------------------------------
3 Feb 18:49:07 - [warn] Failed to register 2 node types
3 Feb 18:49:07 - [warn] Run with -v for details
3 Feb 18:49:07 - [info] Settings file : /root/.node-red/settings.js
3 Feb 18:49:07 - [info] User directory : /root/.node-red
3 Feb 18:49:07 - [info] Flows file : /root/.node-red/flows_16c9f0b4f522.json
3 Feb 18:49:07 - [info] Server now running at http://127.0.0.1:1880/
3 Feb 18:49:07 - [info] Starting flows
3 Feb 18:49:07 - [info] Started flows
3 Feb 18:49:07 - [info] [mqtt-broker:a1398bca.262398] Connected to broker: mqtt://192.168.1.111:188
You need to upgrade.
Node-RED is currently on v0.19.5
Manage pallete was an added feature of v0.15
nodejs v4 was end-of-lifed almost a year ago
Many thanks,
Any idea as to how the upgrade could be carried out.
Where did you get your original docker image from?
Thanks Guys, I installed a different version and now am able to manage pallets.
Thanks again
Peter
