Node-Red installation offline?
Hi folks!
I need some urgent help, please! I need to install node-red on a windows machine without internet access.
NPM has been installed, but I´m struggling with NR. I dont understand the solutions which can be found a few years ago in this forum. :frowning:
Describe what you've tried and how it didn't work.
Also read
Wow, that was easy! How can I add nodes?
Install nodes before you zip up & copy to other machine
If you later add further nodes, make sure you don't overwrite the flows file etc on the non-networked machine. After the first time you only need to copy across package.json, package-lock.json and the node_modules folder, and then restart node-red.
