I'm looking for some help troubleshooting a PLC connection issue.
I'm using the node-red-contrib-cip-st-ethernet-ip nodes to communicate with an Allen-Bradley ControlLogix L83 PLC. The connection has been working reliably for about a month, but today the PLC connection node suddenly started showing Offline.
Here are a few things I've checked:
I can successfully ping the PLC's IP address from the PC running Node-RED.
No configuration changes have been made on the PLC.
The PLC is still running normally and controlling the process.
The only issue is that Node-RED can no longer establish a connection to it.
I'm trying to figure out what could cause this behavior and where I should start troubleshooting. Has anyone experienced something similar or have suggestions on what to check next?
Any advice would be greatly appreciated. Thanks!
