No, and I have checked that it isn't behind any other windows. There was a a notification popup saying
MCU is initiazing
Flows are ready
but that is all.
Nothing indicating a problem in syslog.
MCU is initiazing
Flows are ready
but that is all.
Flows are ready is signaled by the flow (!) after it has launched successfully.
Thus your MCU is already up & running.
Sorry to ask: Have you checked your Debug panel for a message?
In case xsbug terminated, you may reconnect via the context menu (down-arrow-button) of the Build button...
That happens when the config parameters of the selected target platform conflict with the physically connected hardware.
FYI: Based on your comment I added two additional generic platform identifiers, esp & esp32. Thank you for triggering this change!
I propose you pull the latest update of the plugin from GitHub.
There's now a config option called Debug Target that allows to use xsbug-log in case of headless setups. You need to select console to enable xsbug-log; default is still xsbug.
I am watching this a while and didn´t wanna destroy your discussion. I ve some basic things I never got. Node Red on an ESP sounds cool stuff. - I thought first. But With a look at my ESP projects: sensors, switches ... etc. I am asking myself how to get such stuff work !? When working with C++ I can use a bunch of library's for all kind of modules. Do you need to recode all that in some kind (nodeJS) or make a big database of nodes for modules ? I don t know what s the typical use-case: Maybe some more smarter ppl than I am could tell me
Thx!
PS: If I am still exited about this project it needs a more easy step by tutorial variant than this ^^ for me to get it working ![]()
The guys from Moddable already have supported two sensors for me, and the wt32-eth01 board. They are very helpfull, but of course we cannot expect them to support every sensor available. Rome was also not build in one day...
Same for me. I have planned to write one, but I first need to get it running myself...
Yes, a necessary question though. ![]()
I pulled the latest version from github and much progress has been made.
Almost everything is working like magic ![]()
I added MQTT in and out nodes and the nodes show connected.
A debug node connected to the MQTT In displays correctly in a debug window.
The MQTT In, connected to the MQTT out, works and does publish correctly as can be seen in an MQTT client.
The only problem I can see at the moment is that If I click the Inject node everything stops. The MQTT pass through stops, which suggests that maybe the ESP device has crashed, or been stopped. If I reconnect to xsbug then it all starts up again.
[Edit] Further to this, if I set the inject to fire automatically every 5 seconds then that works perfectly. It is manually clicking the inject button that kills it.
Could you please open an issue at the plugins repo & attach the flow file (sanitized).
I've seen this occasionally, yet only with heavy loaded flows.
An example that helps us to reproduce is very appreciated!
Done: Flow stops when clicking Inject node · Issue #15 · ralphwetzel/node-red-mcu-plugin · GitHub
Now I have to work out what I can usefully do with new-found capability.
Is it possible to access the analogue input on the mcu? I see it referenced the node-red-mcu docs, but it isn't clear to me how to access it.
There's a node in the sensor package that supports analog reading.
Be aware though that the Moddable team is still working on integrating this package for the plugin...
OK, I will leave that for the moment.
If I wanted to make one of my contrib nodes available what would be the procedure for doing that? Is it something I can do myself (it is a fairly simple node)?
FYI, I have a repeating inject node sending the timestamp to a MQTT output node. I am not experiencing the failure when I manually activate the input node. But I am not using any passthrough. I have given the ESP32 my WiFi credentials on the build.
Sure... and you've bullseyed that piece of documentation, that's not written yet! ![]()
On the other hand - if it really is a simple node - just test what's happening, when you pull it into a flow & try to build. The plugin understands a package.json and walks the full dependency tree in its intent to integrate what's necessary. Depending on the result, I'll guide you through your options...
I get
Starting build process...
Host system check: #64-Ubuntu SMP Thu Jan 5 11:43:13 UTC 2023
MCU Build system check: p1.1.2-post + #14cd68e @ m3.7.0-0-g74aa31c
HOME directory check: /home/colinl
Creating build environment for platform esp/nodemcu.
Working directory: /home/colinl/.node-red/mcu-plugin-cache/xbu2qex629n
$ESP_BASE identified: /home/colinl/esp
> cd /home/colinl/.node-red/mcu-plugin-cache/xbu2qex629n
Creating build script file...
> /bin/bash ./build.sh
# nodered2mcu flows
# xsc main.xsb
# xsc node-red-contrib-timeprop.xsb
# mcrez resources
# xsc flows.xsb
Total resource size: 0 bytes
# xsl modules
# cc mc.resources.c (slots in flash)
ReferenceError: module "file" not found
### ReferenceError: module "file" not found!
make: *** [/home/colinl/Projects/moddable/build/tmp/esp/nodemcu/debug/xbu2qex629n/makefile:808: /home/colinl/Projects/moddable/build/tmp/esp/nodemcu/debug/xbu2qex629n/mc.xs.c] Error 22
Though I don't have any file manipulation in my node. Or does that mean I need to install something to build it?
I am just starting to look at things but it seems that you need to put your contrib node here: ~/.node-red/node_modules/@ralphwetzel/node-red-mcu-plugin/node-red-mcu/nodes
Jus guessing though as that is where I found the other nodes.
Don't do!
Just install your mcu-only or dual-use node like any other node.
Those interested in an example of what's possible & how things play together may refer to the heartbeat node - currently available on GitHub only. Be aware that it has zero documentation yet...
ok, my apologies...
Any suggestions what to do about the module not found error?
Sorry. I can't reproduce this.
Could you please check if the error persists when you build for a simulator target or an ESP32? No hardware necessary though...
FYI: I've experimented as well w/ your contrib-node. The flow builds without any change. But ... the MCU runtime doesn't like that you're sending null as a message & and throws an exception.
