Node-red-node-wol Class A IP-Adress
I successfully used the module node-red-node-wol to wake up a PC in a class C network with the IP 192.168.55.156 and the following setup IP: 192.168.55.255
Now the network changed to class A and the adress 10.55.5.156. I tried different IP-configurations with 255 replacing the other numbers but the PC does not boot up.
Does anybody knows, what the problem may be?
Thanks, Michael
Found out how to do it. Replace the whole IP with 255.255.255.255.
