n2048
3 June 2022 11:59
1
I have aa docker-composes environment wheree all the services are routed and protected through a KONG gateway.
I recently added aa node-red service to the infrastructure but I can't seem to make it fully work.
The interface allows me to edit and deploy new flows, but I can keep getting the "Lost connection to the server" message, and I cannot ddebug on the web interface.
I suspect that it's a misssconfiguration on the kong route or service that might be blocking the wss traffic.
Anyone has any experience combining all this?
Or, you have done something in your flows that is causing node-red to crash and restart.
Is there any logging on this device?
n2048
3 June 2022 13:15
3
Happens even with empty flows.
And the flows work. But can't do web debug and keep getting that "disconnected" message
Did you manage to configure Kong Gateway ?
I've been experimenting with it also a few months ago.
Im sharing my docker-compose file and Kong config .yml file (db-less).
Most of the Kong plugins are disabled and are just there for testing based on this Tutorial
docker-compose.yml
version: '3.3'
services:
kong:
image: kong
volumes:
- "./config:/usr/local/kong/declarative"
environment:
- KONG_DATABASE=off
- KONG_DECLARATIVE_CONFIG=/usr/local/kong/declarative/kong.yml
- KONG_PROXY_ACCESS_LOG=/dev/stdout
- KONG_ADMIN_ACCESS_LOG=/dev/stdout
- KONG_PROXY_ERROR_LOG=/dev/stderr
- KONG_ADMIN_ERROR_LOG=/dev/stderr
- KONG_ADMIN_LISTEN=0.0.0.0:8001, 0.0.0.0:8444 ssl
- KONG_LOG_LEVEL=debug
- KONG_PLUGINS=bundled
ports:
- "8000:8000/tcp"
- "127.0.0.1:7990:8001/tcp"
- "8001:8001/tcp"
- "8443:8443/tcp"
- "127.0.0.1:8444:8444/tcp"
kong.yml (in ./config folder)
_format_version: "2.1"
services:
- name: nodered-server
url: https://192.168.0.7:1880
routes:
- name: nodered
paths:
consumers:
- username: user
basicauth_credentials:
- consumer: user
username: Aladdin
password: OpenSesame
keyauth_credentials:
- consumer: user
key: abc
acls:
- consumer: user
group: group1
plugins:
- name: request-size-limiting
config:
allowed_payload_size: 1
size_unit: kilobytes
require_content_length: false
enabled: false
- name: request-termination
config:
status_code: 403
# message: So long and thanks for all the fish!
body: "{a:b}"
content_type: "application/json; charset=utf-8"
trigger: "q"
enabled: false
- name: acl
config:
allow:
- group1
hide_groups_header: true
enabled: false
- name: basic-auth
config:
hide_credentials: true
enabled: false
- name: key-auth
config:
key_names:
- apikey
key_in_body: false
key_in_header: true
key_in_query: true
hide_credentials: false
run_on_preflight: true
enabled: false
- name: proxy-cache
config:
response_code:
- 200
request_method:
- GET
- HEAD
content_type:
- text/plain
- application/json
- application/json; charset=utf-8
cache_ttl: 300
strategy: memory
enabled: false
- name: bot-detection
config:
deny:
- "(C|c)hrome"
- "curl"
enabled: false
- name: cors
config:
origins:
methods:
- GET
- POST
headers:
- Accept
- Accept-Version
- Content-Length
- Content-MD5
- Content-Type
- Date
- X-Auth-Token
- Authorization
exposed_headers:
- X-Auth-Token
credentials: true
max_age: 3600
preflight_continue: false
- name: rate-limiting
config:
# second: 5
hour: 100
policy: local
fault_tolerant: true
hide_client_headers: false
redis_ssl: false
redis_ssl_verify: false
# comment these if you don't want to store rate limiting data in redis
# policy: redis
# redis_host: 172.27.59.36
# redis_password: example
enabled: false
- name: ip-restriction
config:
deny:
- 172.28.64.0/24
status: 401
message: cannot grant access
