I cloned the repository git@github.com
/node-red.git, executed the commands npm install, npm build, and npm start using NodeJS version 20.
$ npm run start
> node-red@4.0.2 start
> node packages/node_modules/node-red/red.js
12 Jul 11:25:48 - [info]
Welcome to Node-RED
12 Jul 11:25:48 - [info] Node-RED version: v4.0.2
12 Jul 11:25:48 - [info] Node.js version: v20.15.1
12 Jul 11:25:48 - [info] Linux 6.8.0-36-generic x64 LE
12 Jul 11:25:48 - [info] Loading palette nodes
12 Jul 11:25:49 - [info] Settings file : /home/antonio/.node-red/settings.js
12 Jul 11:25:49 - [info] Context store : 'default' [module=memory]
12 Jul 11:25:49 - [info] User directory : /home/antonio/.node-red
12 Jul 11:25:49 - [warn] Projects disabled : editorTheme.projects.enabled=false
12 Jul 11:25:49 - [info] Flows file : /home/antonio/.node-red/flows.json
12 Jul 11:25:49 - [info] Creating new flow file
your credentials.
12 Jul 11:25:49 - [warn] Encrypted credentials not found
12 Jul 11:25:49 - [info] Starting flows
12 Jul 11:25:49 - [info] Started flows
12 Jul 11:25:49 - [info] Server now running at http://127.0.0.1:1880/
Apparently, the service is running, as indicated by the response from the npm start command.
Furthermore, the netstat -tulnp command also indicates that the node-red process is listening on the default port 1880.
$ netstat -tulnp | grep 1880
tcp 0 0 0.0.0.0:1880 0.0.0.0:* LISTEN 1758419/node-red
My firewall (ufw) is disabled. I am using Ubuntu 24.04 LTS (Noble).
$ ufw status
Status: inactive
The problem is that it is not accessible via the browser.
This site can’t be reached.
Check if there is a typo in localhost.
DNS_PROBE_FINISHED_NXDOMAIN.
What could be happening?
