Hi all
I am using Python 3 in my project.
I am python3-function and I would like the font size in the editor to be larger.
It's possible?
Thanks in advance
Hi all
It's possible?
Thanks in advance
It is possible by hacking the node or adding some CSS overrides.
Unfortunately, I would suggest switching to monaco editor where setting the font size is trivial BUT this node looks to have been abandoned (has not been updated in in over 5 years) and has outstanding ISSUE regarding loading ACE and not supporting monaco editor due to the way it was written.
Thanks Steve
which node can i use to use python 3 on node red?
Its a loaded answer...
1st - a question: What are you doing in python that couldnt be done in node-red?
Alt solution...
Run your python via an exec node.
I'm using a Adafruit servo motor board.
With Python works fine and now i would like use it with Node Red
Starting a new post or renaming this post will likely draw more attention from the users who might have done this.
e.g. something like "How to control Adafruit servo motor from node-red"
