Nodered is abruptly terminate while connecting with cratedb and fetching data from it
Hi all,
i am trying to connect nodered with cratedb node and fetching data from it.
But nodered is abruptly terminated.
Below is the logs:
2 Feb 17:04:00 - [red] Uncaught Exception:
2 Feb 17:04:00 - Error: connect EINVAL 0.0.16.104:4200 - Local (0.0.0.0:0)
at internalConnect (net.js:882:16)
at defaultTriggerAsyncIdScope (internal/async_hooks.js:294:19)
at GetAddrInfoReqWrap.emitLookup [as callback] (net.js:1029:9)
at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:61:10)
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! node-red@1.0.3 start: node packages/node_modules/node-red/red.js
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the node-red@1.0.3 start script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! /root/.npm/_logs/2020-02-02T11_34_00_544Z-debug.log.
Below is the nodered flow
[{"id":"4f0c52d3.bb3f0c","type":"tab","label":"Flow 8","disabled":false,"info":""},{"id":"4c75de04.47a5c","type":"crate in","z":"4f0c52d3.bb3f0c","name":"crate","database":"43d9b0e8.ac4ef","x":260,"y":160,"wires":[["6c9c35de.5141ac"]]},{"id":"c3fe9791.a3ea68","type":"inject","z":"4f0c52d3.bb3f0c","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":true,"onceDelay":0.1,"x":90,"y":80,"wires":[["dbfcc7c.01b0738"]]},{"id":"6c9c35de.5141ac","type":"debug","z":"4f0c52d3.bb3f0c","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":560,"y":220,"wires":[]},{"id":"dbfcc7c.01b0738","type":"function","z":"4f0c52d3.bb3f0c","name":"","func":"msg.query=\"SELECT * FROM doc.etairqualityobserved LIMIT 100 where text like ?;\"\nmsg.args=['%moderate%']\nreturn msg;","outputs":1,"noerr":0,"x":450,"y":60,"wires":[["4c75de04.47a5c"]]},{"id":"43d9b0e8.ac4ef","type":"crate","z":"","url":"172.30.76.56:4200","name":"etairqualityobserved"}]
port 4200 looks like cratedb. As it's an async error we can't do anything sensibly apart from exit cleanly. That node need to handle that error - so best to contact the author and ask for help (if the issue has not already been raised)
