chiru
2 November 2023 12:25
1
When I press on the output port of a node and drag and stop on the workspace, a placeholder node appears. Along with that a search bar and list of nodes appear as below. In the list my custom nodes names also appear.
However, when I disabled all the nodes in nodered (except my custom nodes) in settings.js by adding the nodes in nodesExcludes : list, performing same action as above results in the appearance of placeholder node, however, search bar along with my custom nodes doesn't appear as show in below representation purpose only image) and workspace freezes. How can I fix this issue
I'm not sure why someone will disable all nodes in Node RED - will make it a pretty dull place to work in if so.
Anyway,
its likely an edge case - can you document the nodes you have disabled (paste your nodesExcludes value)
and someone else will test it, if reproducible, we will need you to raise as bug.
EDIT:
Also your Node & Node RED version & browser
chiru
3 November 2023 05:17
3
Hi @marcus-j-davies , thanks for the reply.
I disabled all the nodes in Node RED so that I can display only my custom nodes.
nodesExcludes: ['05-junction.js', '24-complete.js', '20-inject.js', '21-debug.js', '25-catch.js', '25-status.js', '60-link.js', '90-comment.js', '98-unknown.js', '10-function.js', '10-switch.js', '15-change.js', '16-range.js', '80-template.js', '89-delay.js', '89-trigger.js', '90-exec.js', 'rbe.js', '05-tls.js', '06-httpproxy.js', '31-tcpin.js', '32-udp.js', '10-mqtt.js', '21-httpin.js', '22-websocket.js', '21-httprequest.js', '70-CSV.js', '70-HTML.js',
'70-JSON.js', '70-XML.js', '70-YAML.js', '17-split.js', '18-sort.js', '19-batch.js', '10-file.js', '23-watch.js']
Node version - v16.17.0
Node RED version - node-red@3.1.0
Browser - Chrome
I normally put the node before I put the wire.
(If that helps)
chiru
3 November 2023 05:26
5
@Trying_to_learn ,
yes, putting the node and then connecting the wire works fine. But this specific case is causing the issue
But sorry...
Is it you put the catch node and then are putting a wire to..... (??) and let go in mid air and the requestor pops up?
But it doesn't happen with other nodes?
I'm not trying to dismiss what you are saying, I'm trying to understand what's happening.
I know I (a long time ago now) had problems with some program it was doing weird things.
I started looking at the problem - as are you - and found it was the mouse button faulty.
So I would be dragging the mouse with the LMB down and it would release in mid flight between where it started and where I was going and causing things to happen I wasn't wanting.
So - for me - it was a mouse button causing problems.
chiru
3 November 2023 05:35
7
yes, you are right. As @marcus-j-davies mentioned, this might be a edge case issue
Something else - and sorry to hijack the thread - what version of NR, what version of NODE.JS and what O/S are you using?
chiru
3 November 2023 05:37
9
Browser - Chrome
OS - Ubuntu 20.04.6 LTS
Thanks.
And which O/S?
That may be of importance too.
Just to put it out there.
I'm similar and if I put a catch node and do what you say: nothing happens.
But there again, I don't know if have the settings you have for how nodes are put on the work area.
NR 3.0.2
node.js 16.20.2
O/S Ubuntu 22.04 LTS
chiru
3 November 2023 05:44
12
@Trying_to_learn ,
Yes, may be due to difference in settings. Yet, it should be easily reproducible.
could you specifically say which one you have set ?
And sorry I just looked you did specify all the stuff I asked for in your first post.
I am having a real bad time reading these days.
chiru
3 November 2023 06:18
14
@Trying_to_learn , I just checked the same without any changes in settings (apart from nodesExcludes list) too and same issue happens. I think it is better to wait for @marcus-j-davies reply and see if it can be fixed easily.
Thanks @chiru
I can reproduce it.
Browser : Safari
Node RED : 3.1.0
Node : 18.18.0
Console Error:
Can you raise a bug - and make reference to this thread?
chiru
3 November 2023 06:38
16
@marcus-j-davies . Thanks for checking.
sure.. I will raise the bug
chiru
3 November 2023 07:19
17
@marcus-j-davies
I have raised the bug on github
opened 07:18AM - 03 Nov 23 UTC
needs-triage
### Current Behavior
When nodes in nodered are disabled (except custom nodes) k… eeping only custom nodes (tested 5 different kinds of custom nodes) by adding the nodes in _nodesExcludes_ list in settings.js and then, when I press on the output port of a custom node in workspace and drag and drop on the workspace, a placeholder node appears. However, search bar and list of nodes doesn't appear as shown in below representation purpose only image) and workspace freezes and no more actions can be performed
**Pleae refer below thread for detailed description :**
https://discourse.nodered.org/t/nodered-workspace-freezes-when-placeholder-node-appears-when-only-custom-nodes-are-enabled/82550
### Expected Behavior
When I press on the output port of a custom node and drag and drop on the workspace, placeholder node should appear. Along with that a search bar and list of my available custom nodes should appear as shown in below image.
### Steps To Reproduce
1. Add few different types of custom nodes to Node RED.
2. Disable default nodes in Node RED by adding them to nodesExcludes list
nodesExcludes: ['05-junction.js', '24-complete.js', '20-inject.js', '21-debug.js', '25-catch.js', '25-status.js', '60-link.js', '90-comment.js', '98-unknown.js', '10-function.js', '10-switch.js', '15-change.js', '16-range.js', '80-template.js', '89-delay.js', '89-trigger.js', '90-exec.js', 'rbe.js', '05-tls.js', '06-httpproxy.js', '31-tcpin.js', '32-udp.js', '10-mqtt.js', '21-httpin.js', '22-websocket.js', '21-httprequest.js', '70-CSV.js', '70-HTML.js', '70-JSON.js', '70-XML.js', '70-YAML.js', '17-split.js', '18-sort.js', '19-batch.js', '10-file.js', '23-watch.js']
3. Drag and drop a custom node to workspace.
4. Press on the output port of a custom node in workspace and drag and drop on the workspace, a placeholder node appears. However, search bar and list of nodes doesn't appear.
### Example flow
_No response_
### Environment
- Node-RED version: 3.1.0
- Node.js version: 16.17.0
- npm version: 8.15.0
- Platform/OS: Ubuntu 20.04.6
- Browser: Chrome
Thanks - I'm not part of the core team, but should get looked at by them.
I added my gif
chiru
3 November 2023 07:30
19
Sure.. @marcus-j-davies Thanks for the quick support. It was very helpful.
I have the fix, but airplane WiFi is getting in the way of pushing it. Rest assured we'll have it in 3.1.1
