Hi All,
I have a weird situation with my NORA First and Only Switch I have setup till now.
This is my settings:
I have setup the account and got the Token - installed the component in Node RED and was able to create my NORA Switch. I have set everything up that way it will have the Room hint and it will be easy for me to find it.
But, The problem I have is that - I can find it in my Google Home account when I search for Rooms but I can't find it to be able to control it with a GUI>
I will explain - When I ask Google to turn it ON or OFF it works just fine. As well as if I search the room, Where I put it, I can see the Device counted there and also see the name I gave it.
Problem Starts when I go to HOME in my Google account and search for it in order to be able to control it using the GUI of a Switch - I can NOT find it at all.
I have the ability to control the device using voice command BUT I can't control it using the GUI - I don't see the GUI at all.
I have updated my Google Home to the latest version - revoked the token several times and also removed permissions from my Gmail account to re-enable it again with no luck at all. I have removed the NORA account several times and still Nothing shows up in the GUI - But it can be controlled using Voice Command with my Google assistant on my Devices at home.
I would be happy to have your assistant on that.
Thanks you!
