Nuke it from orbit
I'm having problems installing/upgrading Node-RED on an older PiZero (Stretch so not ancient)
(Its in the endless loop of saying that its not fully installed and do I want to re-install)
I've tried loads of things and I'm now at the stage where I'd like to delete all Node-RED files, remove npm and remove node.js and start again
sudo rm what?
Why not just flash the SD card?
Obvious really :slight_smile:
Just copying all the files from /home/pi in case I ever need them :slight_smile:
Mind you - this may take some time ...
Should finish sometime this week.......
If in doubt zip it all up into a single archive then copy.
I'll do that in future - lesson learnt :slight_smile:
No one?
https://youtu.be/nnHmUk_J6xQ?t=25
