OCPP Server Url
Hello everyone,
I would like to coonect an EVSE charge point to an OCPP server in the Node Red. This topic is quite new for me and I have no idea how to do. In EVSE side I can configure WiFi:
as its evident in the photo, in the upper part I insert my mobile hotspot credential and
below I can configure the charge point which is the most critical part is OCPP Server that
I don't know how can I define OCPP server in order to recieve data from charge point and send
command. I would appreciate it if you give me an idea.
You do realise that you've shared private details in a public forum? You should probably at least change your WiFi password.
Have you checked the flow library for a suitable node? I believe there is at least 1?
It was test credential! but I marked the information. Thanks for your warning.
Yes I checked the examples also, I think this node is good for receiving data through OCPP
I defined the same Url in EVSE WiFi configuration and WiFi LED in charger point is blinking which means
connection to server is normal but when I check the RFID tag in charge point I don't recieve anything!
