Ok, what's going on with this message?
I've bitten the bullet and am re-writing old flows.
While messing around with one, I am seeing this payload
{"payload":1,"event":{"clientX":367,"clientY":195,"bbox":[327,222,483,174]},"socketid":"AiZlnOlnlm43IvokAAAB","_msgid":"91139a7.46f8c68","colour":"lime","txt":"Enabled","fontclr":"black","topic":"CONTROL"}
The flow isn't that complicated.
Where is this "event":{"clientX":367,"clientY":195,"bbox...... coming from?
I can post the part of the flow if desired.
All we can say is it is coming from a node-red-dashboard node.
Other than that, we can't really say anything else.
I assume this is appearing in the Debug sidebar? I assume you have used all the usual methods for identifying which Debug node that message came from and tracking it back from there?
Well, this is the flow:
[{"id":"32b67a5d.231c86","type":"inject","z":"1781e581.31721a","name":"Setup","topic":"","payload":"foo","payloadType":"str","repeat":"","crontab":"","once":true,"onceDelay":"3","x":2500,"y":730,"wires":[["49d7ad48.0f8b54"]]},{"id":"49d7ad48.0f8b54","type":"function","z":"1781e581.31721a","name":"Setup","func":"msg = {\n    \"colourA\": \"red\",\n    \"colourB\": \"lime\",\n    \"txtA\": \"Disabled\",\n    \"txtB\": \"Enabled\",\n    \"txtclrA\": \"black\",\n    \"txtclrB\": \"black\",\n    \"payloadA\": 0,\n    \"payloadB\": 1,\n    \"topicSET\": \"CONTROL\"\n}\nreturn msg;","outputs":1,"noerr":0,"x":2630,"y":730,"wires":[["203af629.7c0bba","2dc74b3c.896bc4"]]},{"id":"16f7601f.88c79","type":"ui_button","z":"1781e581.31721a","name":"Push Button 1","group":"fefa8817.8dc6c8","order":1,"width":"3","height":"1","passthru":false,"label":"{{msg.txt}}","tooltip":"","color":"{{msg.fontclr}}","bgcolor":"{{msg.colour}}","icon":"","payload":"X","payloadType":"str","topic":"","x":2660,"y":770,"wires":[["203af629.7c0bba"]]},{"id":"203af629.7c0bba","type":"function","z":"1781e581.31721a","name":"Push Button","func":"var state = context.get(\"STATE\")||0;\n\n//  Look for a !X message to get values.\nif (msg.payload != \"X\")     //Do this if the message is NOT \"X\"\n{\n    //\n    //node.warn(\"Setting up\");\n    //  Background colours first.\n    //\n    context.set(\"ABGC\", msg.colourA);\n    context.set(\"BBGC\", msg.colourB);\n    //\n    //  Now do text.\n    //\n    context.set(\"Atxt\", msg.txtA);\n    context.set(\"Btxt\", msg.txtB);\n    //\n    //  Font colours.\n    //\n    context.set(\"AFC\",msg.txtclrA);\n    context.set(\"BFC\",msg.txtclrB);\n    //\n    //  Payloads.\n    //\n    context.set(\"PayloadA\", msg.payloadA);\n    context.set(\"PayloadB\", msg.payloadB);\n    //\n    //  Topic.\n    //\n    if (msg.topicSET !== null)\n    {\n        context.set(\"Topic\",msg.topicSET);\n    } else\n    {\n        context.set(\"Topic\",\"~\");\n    }\n    msg.colour = msg.colourA;\n    msg.fontclr = msg.txtclrA;\n    msg.txt = msg.txtA;\n    msg.topic = msg.topicSET;\n    msg.payload = msg.payloadA;\n    return msg;\n}\n//      Now on to the real stuff.\nif (msg.payload == \"X\")\n{\n    state = (state + 1)% 2;\n    //node.warn(state);\n    context.set(\"STATE\",state);\n}\nif (state === 0)\n{\n    //  Condition A\n    msg.payload = context.get(\"PayloadA\");\n    msg.colour = context.get(\"ABGC\");\n    msg.txt = context.get(\"Atxt\");\n    msg.fontclr = context.get(\"AFC\");\n} else\n{\n    //  Condition B\n    msg.payload = context.get(\"PayloadB\");\n    msg.colour = context.get(\"BBGC\");\n    msg.txt = context.get(\"Btxt\");\n    msg.fontclr = context.get(\"BFC\");\n}\nif (context.get(\"Topic\") == \"~\")\n{\n    msg.topic = \"\";\n} else\n{\n    msg.topic = context.get(\"Topic\");\n}\nreturn msg;\n","outputs":1,"noerr":0,"x":2650,"y":820,"wires":[["16f7601f.88c79","9e5facf.d7f10d","71190f2d.713178"]]},{"id":"9e5facf.d7f10d","type":"debug","z":"1781e581.31721a","name":"Output","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":2820,"y":770,"wires":[]},{"id":"fefa8817.8dc6c8","type":"ui_group","z":"","name":"Audio","tab":"b128eb09.9f681","order":3,"disp":true,"width":"4","collapse":false},{"id":"b128eb09.9f681","type":"ui_tab","z":"","name":"TV_Remote_control","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
Screen shot:
I have never seen such messages with these attributes before on any flow I have worked.
Digging, it would seem it is coming from the button icon.
As much as I am at odds with buttons just now, I have handled a lot of messages from buttons and can honestly say I have not seen these attributes (?term?) on any message before.
I'll check another machine for the sake of making myself look (more) stupid than I am.
They were added in a very recent version of Node-RED dashboard. If you've only just upgraded this to the latest version of dashboard, then you won't have seen them before.
Phew!
Yes, I did update the dashboard on..... (today's Tuesday.) Maybe Late LATE Sunday or maybe Monday.
That's a big relief.
paranoia had nearly set in about the bad luck on this machine and what has recently happened.
Wasn't sure if it was a nasty I had picked up.
Though that would be difficult, as it shouldn't be possible as I have no open ports on this machine.
{{thanks}} -- that's saved a lot of nappy use.
:wink:
If you want to know what they are and how you can use them, see - Contextmenu location
I try to not get into core development stuff too often.
But again: Thanks.
It seems a bit over my head what I am reading.
