OMRON NX102 FINS Communication Issues
They would/should be the same network
One thing i note - auto connect is disabled. Any reason? Are you commanding the node to connect as described in the built in help? I would recommend until you get up and running to leave "Auto Connect ` checked. FYI, in Node-RED, whenever you change a setting on a node, it is completely destroyed and re-created (i.e. connection is re-established with the new parameters you enter)
Did you check computer firewall?
Can you run wireshark to confirm packets are being sent?
Can you attach a debug (set to show complete msg) to the output of your FINS Read node. Also, add a catch node that is aimed at the FINS Read node & link that to a debug node (also set to show complete msg). Capture the full msg and post in a reply.
How to capture debug data for posting
BX00Cy7yHi
How to post well formatted code/json etc
   code goes here
You can edit and correct your post by clicking the pencil :pencil: icon.
