I use OWFS (with node-red-contrib-owfs) but not on Windows, and I see from there website that Windows support may not be fully stable. The fact that you have had no response here may mean that you will be on your own if you try that route.
If see by searching the flows site that there are some other 1-wire nodes, but whether they work on Windows I don't know.
I think most that use 1-wire do this on Pis, in which case it is very easy. You might like to consider this route.
