Optimize the flow management panel
At present, the platform has 80 flow and needs to optimize the flow management panel
Problem:
1、Slow opening speed
2、There is no hierarchy in management
Hope for improvement:
Add close button to each tab
flow can be saved and opened through catalog
Reference example:
That is not Node-RED - what software are you using?
The screenshot is a reference for how other apps do it.
@cmdares when you raised this on the GitHub issue list I asked you to search the the forum for where this has been discussed at length before. Have you done so?
Thank you for your attention.
old topic: Flow multi-level management
I have asked similar questions before, but I didn't express them clearly, so I created a new one and described it as carefully as possible. As I said, a large number of flows need to be managed more reasonably.
I hope my suggestion can be adopted.
Thanks!
