Hi, I have been using node-red on a pi with osmc installed for quit a while without problem, however I now want to use the gpio nodes in a flow, I know node-red is not designed specifically to run on osmc but all my other flows work fine.
When I try to use a gpio node says Stopped and if I initiate the node it says not running I get [error] [rpi-gpio out:7ed8bdf2.dd8014] nrpgio python command not running in the console.
I can successfully run a python script from the commend line with sudo ./test.py it contains the following code
#!/usr/bin/env python
import RPi.GPIO as GPIO
import time
GPIO.setmode(GPIO.BCM)
GPIO.setwarnings(False)
GPIO.setup(24, GPIO.OUT)
GPIO.output(24, GPIO.HIGH)
time.sleep(1)
GPIO.output(24,GPIO.LOW)
For info .
Welcome to Node-RED
18 Feb 17:53:24 - [info] Node-RED version: v0.19.5
18 Feb 17:53:24 - [info] Node.js version: v10.15.1
18 Feb 17:53:24 - [info] Linux 4.14.78-4-osmc arm LE
18 Feb 17:53:25 - [info] Loading palette nodes
18 Feb 17:53:30 - [info] Settings file : /home/osmc/.node-red/settings.js
18 Feb 17:53:30 - [info] Context store : 'default' [module=memory]
18 Feb 17:53:30 - [info] User directory : /home/osmc/.node-red
18 Feb 17:53:30 - [warn] Projects disabled : editorTheme.projects.enabled=false
18 Feb 17:53:30 - [info] Flows file : /home/osmc/.node-red/flows_osmc.json
osmc@osmc:~$ groups (returns)
osmc adm disk lp dialout cdrom audio video gpio i2c
osmc@osmc:~$ python --version (returns)
Python 2.7.13
I have added the following but they do not help.
sudo adduser $USER gpio
and NodeREDusername ALL=(ALL) NOPASSWD: /usr/bin/python to visudo
Anyone any ideas what I could try to get this working ?
