I am trying to create a table that has to populate the headers based on a drop-down selection. The UI Template code for the table is as follows
<table class="GeneratedTable">
<thead>
<tr>
<th><div align="left">SN:</div></th>
<th><div align="left">Timestamp</div></th>
{{msg.code}}
</tr>
</thead>
<tr ng-repeat="row in msg.payload | limitTo:5000 ">
<td>{{$index+1}}</td>
<td><div align="left">{{row.timestamp}}</div></td>
<td><div align="left">{{row.data1}}</div></td>
<td><div align="left">{{row.data2}}</div></td>
</tr>
</table>
the {{msg.code}} moustache is a string generated based on the dropdown selection, for example:
<th><div align="left">DATA1</div></th>
<th><div align="left">DATA2</div></th>
however it doesn't seem to populate the table header, the moustache code just appears above the table header. If I paste the above code the table is populated. Can someone let me know what I am doing wrong?
Try triple curly brackets (see the template node built-in help for why)
tried that just now, the table appeared as below
here is the full code for UI template
<!-- CSS Code: Place this code in the document's head (between the 'head' tags) -->
<style>
table.GeneratedTable {
width: 100%;
background-color: #d1eaea;
border-collapse: collapse;
border-width: 2px;
border-color: #ffffff;
border-style: solid;
color: #000000;
table.GeneratedTable td, table.GeneratedTable th {
border-width: 2px;
padding: 10px;
table.GeneratedTable thead {
background-color: #9690ea;
</style>
<!-- HTML Code: Place this code in the document's body (between the 'body' tags) where the table should appear -->
<thead>
<tr>
{{{msg.code}}}
</tr>
</thead>
<tr ng-repeat="row in msg.data | limitTo:5000 ">
</tr>
</table>
<p>{{msg.clear}}</p>
<!-- Codes by Quackit.com -->
Add a debug node just before the template g show us what is inside msg.code
kevinksdroid:
UI template
Wait, i missed the fact you were using a ui-template. Mustache syntax is only supported in the template node. You can generate the HTML in a regular template and pass it to a ui-template using msg.template (its in the the built in help)
