Who can show me a GOOD working demo with Piface in basic form
thanks
D
As I understand it, Piface produce a range of plugin hardware interfaces for the Pi, so you would have to ask about a specific Piface product I believe.
The node-red flows site finds three nodes when searching for piface, do any of those help?
Colin Thanks
I try to interface
a working piface in node-red
rpi-piface out en rpi-piface in in flow
but
HOW
And therefore looking for a FLOW with this elements and the config for those elements?
I hope you got enough information to help me
Dick
Which piface node are you trying to use? node-red-contrib-pifacecad, node-red-node-piface or node-red-contrib-piface-digital? If you don't know then look in Manage Palette to see what you have installed.
Also which piface product are you using?
The node readme seems fairly clear. Have you setup the pre-requisites as described there? If yes then what have you tried and what doesn't work?
Ok thanks. I will try this setup you mentioned
But
I should deltree in i raspi-config.
But i cannot find that issue
and the next command is also negative
but i keep trying
gr
Dick
Verzonden vanuit Mail voor Windows 10
It seems you are right and the docs are out of date. I have submitted an issue for this.
Even more serious, possibly, on the wiringpi site I found
" WiringPi did once supportthe PiFace board but support for that is now very much out of date."
So I suggest that maybe you look at the other piface options on the node-red flows site.
I write the a new piFace node and publish this with other nodes next week.
@iiot2k do you mean you are going to update node-red-node-piface? That would be great.
No, its new and works with global variables.
Its a part of a subsystem.
If you need a node that works same as node-red-node-piface node, I can add a second version of this node to github.
