I have some problems with the node-red-contrib-plate-recognizer. It get "bad request" after recognizing the picture that capture by raspberry pi camera module.
Is there any suggestion to solve it?
Are you sure you send a valid picture to my node? You can easily check this by adding a node-red-contrib-image-output node to your flow.
thanks for helping.
I found out my problem which the picture sent was invalid.
