Problem with a Node-red pallet that no longer starts up
Hello
I downloaded this palette:
And now, my Node-Red won't start, here's the error message I get:
juil. 29 18:05:01 GIN Node-RED[33779]: 29 Jul 18:05:01 - [warn] [RED.events] Deprecated use of "nodes-started" event from "/root/.node-red/node_modules/myhabitat/src/nodes/myhabitat.node.js:17:17". Use "flows:started" instead.
juil. 29 18:05:01 GIN Node-RED[33779]: 29 Jul 18:05:01 - [warn] [RED.events] Deprecated use of "nodes-started" event from "node:events:655:8". Use "flows:started" instead.
I want to delete it with Command Line Linux, someone can help me to do that?
That is not an error that will stop node-red from starting up. If you want to see why it not starting up then please post the full startup log.
To know how to uninstall it we need to know how you installed it.
Where can I found the full startup log?
It should be in the same place as the errors you posted. If that is syslog then pipe it into grep -i node-red.
How did you install node red and how do you run it?
I can start the server in safe mode with the command: node-red --safe
If I run the server with the node-red command, here are the live logs and why the server crashes :
node-red
30 Jul 08:15:57 - [info]
Bienvenue sur Node-RED
30 Jul 08:15:57 - [info] Node-RED version: v3.1.3
30 Jul 08:15:57 - [info] Node.js  version: v21.5.0
30 Jul 08:15:57 - [info] Linux 6.1.0-17-amd64 x64 LE
30 Jul 08:15:58 - [info] Chargement des noeuds de la palette
30 Jul 08:15:59 - [info] Fichier de paramètres  : /root/.node-red/settings.js
30 Jul 08:15:59 - [info] Stockage contextuel : 'default' [module=memory]
30 Jul 08:15:59 - [info] Répertoire utilisateur : /root/.node-red
30 Jul 08:15:59 - [warn] Projets désactivés : editorTheme.projects.enabled=false
30 Jul 08:15:59 - [info] Fichier des flux : /root/.node-red/flows.json
(node:525727) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
(Use `node --trace-deprecation ...` to show where the warning was created)
30 Jul 08:15:59 - [info] Le serveur est disponible à l'adresse http://127.0.0.1:1880/
Votre fichier contenant les identifiants de flux est chiffré à l'aide d'une clé générée par le système.
Si la clé générée par le système est perdue pour une raison quelconque, votre fichier contenant
les identifiants ne sera pas récupérable, vous devrez le supprimer et ressaisir vos identifiants.
Vous pouvez définir votre propre clé en utilisant l'option 'credentialSecret' dans
votre fichier de paramètres. Node-RED rechiffrera alors votre fichier contenant les identifiants
à l'aide de la clé que vous avez choisie la prochaine fois que vous déploierez une modification.
30 Jul 08:15:59 - [info] Démarrage des flux
30 Jul 08:15:59 - [warn] [RED.events] Deprecated use of "nodes-started" event from "/root/.node-red/node_modules/myhabitat/src/nodes/myhabitat.node.js:17:17". Use "flows:started" instead.
30 Jul 08:15:59 - [warn] [RED.events] Deprecated use of "nodes-started" event from "node:events:655:8". Use "flows:started" instead.
30 Jul 08:15:59 - [red] Uncaught Exception:
30 Jul 08:15:59 - [error] TypeError: Cannot read properties of undefined (reading 'getEntityStates')
    at MyHabitatNode_Adapter_KNX.stateObject (/root/.node-red/node_modules/myhabitat/src/nodes/myhabitat.node.entity.js:83:23)
    at MyHabitatNode_Adapter_KNX.state (/root/.node-red/node_modules/myhabitat/src/nodes/myhabitat.node.entity.js:90:17)
    at MyHabitatNode_Adapter_KNX.ready (/root/.node-red/node_modules/myhabitat/src/nodes/myhabitat.node.entity.js:44:10)
    at MyHabitatNode_Adapter_KNX.ready (/root/.node-red/node_modules/myhabitat-knx/src/nodes/adapters/myhabitat.node.adapter.knx.js:43:13)
    at MyHabitatNode_Adapter_KNX.allNodesStarted (/root/.node-red/node_modules/myhabitat/src/nodes/myhabitat.node.js:79:10)
    at MyHabitatNode_Adapter_KNX.allNodesStarted (/root/.node-red/node_modules/myhabitat/src/nodes/myhabitat.node.adapter.js:39:13)
    at EventEmitter.<anonymous> (/root/.node-red/node_modules/myhabitat/src/nodes/myhabitat.node.js:17:57)
    at Object.onceWrapper (node:events:633:28)
    at EventEmitter.emit (node:events:519:28)
    at Object.start [as startFlows] (/usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/flows/index.js:411:12)
In safe mode, I can't delete this palette
The answer when i want delete it :
Edit :
I had two myhabitat knx. That's probably why it was crashing
In safe-mode I managed to delete one of them. Now it runs correctly but the second one is simply disabled but I can't delete it. What can I do?
If you want to uninstall myhabitat then
cd /root/.node-red
npm remove myhabitat
and restart node-red.
I don't understand what you mean by
You say you deleted it, do you mean you deleted it by selecting the node in the flow and clicking delete? Then you say it you can't delete it.
When I re-started safe-mode, I realized that I had two palettes that looked identical.
I managed to remove one of them permanently. But another remained, which I could only deactivate (as shown on the screen).
Deactivated, restarting Node-Red as normal, it works again. All I need to do now is remove this useless, non-functional palette.
I've followed your instructions:
root@GIN:~/.node-red# npm remove myhabitat
up to date, audited 64 packages in 895ms
28 packages are looking for funding
  run `npm fund` for details
found 0 vulnerabilities
root@GIN:systemctl restart Node-Red.service
But the remaining palette is still there.
Please post the file .node-red/package.json. or look in there yourself to find the name of the package.
