Problem with connection between Node-Red and Universal Robot
Does anybody figure it out how to connect with UR through NODE-RED?
I am trying to make with Modbus, and TCP/IP communication but I didn’t receive any good result.
Modbus is still loosing connection.
I am no able to figure it out how to properly send command to dashboard server.
There is module called node-red-contrib-ur but unfortunetly it doesn't work.
Please help!
I couldn’t find node-red-contrib-ur, but there is a node-red-contrib-ur-robot. if you mean that node, I’d suggest opening an issue on the nodes github page as it appears to be actively developed, and I’m sure the author would like to know if it didn’t work for you so they can improve the node
