I am trying to connect to twitter node and getting below error.
12 Feb 12:14:58 - [warn] [twitter in:Keyword search] stream error: Error: connect ETIMEDOUT
I am connected on my office network and suspect it is the firewall that is blocking it.
Is there a way to run twitter node behind a proxy? Any workarounds?
EDIT: Same with the feed parser node. I am getting below error:
[error] [feedparse:BT SPORT RSS] Error: ETIMEDOUT
Is there a way to use Twitter/feed parser nodes behind a proxy?
Check with your IT security department as to whether you are allowed to access Twitter over your corporate network. It may be blocked.
I can access twitter on my browser. Is there a way to run the Twitter node behind a proxy?
You can configure a proxy for Node-RED, that may help.
But before going to the effort, talk to your corporate IT.
Spoke to IT, the Twitter node needs to be run behind a proxy but I am not sure if the Twitter node allows that. I don't see any way to do it.
This does not help in running Twitter node behind a proxy.
Hi @faisalchishti
we don't have any immediate plans for the Twitter node. This is the first time the question of running it behind a proxy has come up. I can't imagine it would be too much work to add - just not on my todo list.
If someone wanted to take it on, it would be nice first contribution.
(No need to ping me on twitter - if you want my input on a subject, @-mention me here)
Hi @knolleary
I see issue #243 was raised in 2016 for the same. Hope somebody with the right expertise picks it up and gets it running.
feat(twitter): Add proxy support on twitter node.
#243 opened Oct 18, 2016 by Bigous
Thanks for the update!
