Problems receiving UDP messages
I'm trying to set up a general scenario which consists in a PC sending through UDP OUT node an UDP message to another PC receiving through UDP IN node that message.
Node-red is installed over Windows OS in both cases.
Sended message:
(Not) received message:
Please, note in the previous image that if I send a local UDP message, I recieve it without problems. But the message sended from outside network never arrives.
When I monitor the traffic using Wireshark, I see the incoming message, but it does not appear in the debbug windows of Node-red.
Could anybody help me, please?
Thanks in advance!
Regards,
Ariel
do you have a firewall running ?
Hi dceejay,
Despite I had set a rule in Windows Defender as the following image shows and it's active, it wasn't working.
Only disabling Windows Defender service I could receive from outside.
imagen
I'm sorry but my OS is setting in spanish.
I'll continue analyzing why that rule does not work but, at least, I could identify (from your help) the problem.
Thanks a lot!
Regards,
Ariel
