I'm running Node-RED v0.20.5 on a Ubuntu 18 Virtual Machine with Node.js v8.10.0,
I have created a very simple flow that emails me every 2 minutes to make sure the flow gets properly run. When I start my Node-RED with the command "node-red Email.json", Everything works properly and I get the emails.
The problem comes when I set httpRoot to false on the settings file. When I set it to false and run the same command as before, I get this on the terminal:
pedrojg@pedrojg-VirtualBox:~$ node-red Email.json
23 May 11:34:20 - [info]Welcome to Node-RED
23 May 11:34:20 - [info] Node-RED version: v0.20.5
23 May 11:34:20 - [info] Node.js version: v8.10.0
23 May 11:34:20 - [info] Linux 4.15.0-50-generic x64 LE
23 May 11:34:21 - [info] Loading palette nodes
23 May 11:34:21 - [warn] rpi-gpio : Raspberry Pi specific node set inactive
23 May 11:34:21 - [warn] rpi-gpio : Cannot find Pi RPi.GPIO python library
23 May 11:34:22 - [warn] ------------------------------------------------------
23 May 11:34:22 - [warn] [node-red/inject] Error: Route.post() requires a callback function but got a [object Undefined] (line:113)
23 May 11:34:22 - [warn] [node-red/debug] Error: Route.post() requires a callback function but got a [object Undefined] (line:151)
23 May 11:34:22 - [warn] [node-red/rpi-gpio] Error: Route.get() requires a callback function but got a [object Undefined] (line:364)
23 May 11:34:22 - [warn] [node-red/udp] Error: Route.get() requires a callback function but got a [object Undefined] (line:133)
23 May 11:34:22 - [info] Settings file : /home/pedrojg/.node-red/settings.js
23 May 11:34:22 - [info] Context store : 'default' [module=memory]
23 May 11:34:22 - [info] User directory : /home/pedrojg/.node-red
23 May 11:34:22 - [warn] Projects disabled : editorTheme.projects.enabled=false
23 May 11:34:22 - [info] Flows file : /home/pedrojg/.node-red/Email.json
23 May 11:34:22 - [info] Running in headless mode
your credentials.You should set your own key using the 'credentialSecret' option in
file using your chosen key the next time you deploy a change.23 May 11:34:22 - [info] Waiting for missing types to be registered:
23 May 11:34:22 - [info] - inject
Do you have any ideas as to why this could be and how to solve it?
I have tried installing "Inject" again to see if that was the problem, but it seems that it wasn't.
Any help would be appreciated, thanks!
