Programming ti MSP430 using MSP-FET and Raspberry pi
Hi folks,
I'll shortly be working on a project which will use Node Red on a Raspberry pi 3B, part of this project will involve using the pi to program (firmware upload) a populated PCB under test. The Micro Controller in this case is one from the Texas Instruments MSP430 family.
So this post is really a place for anyone who has relevant info to add (not expecting much of that) and for me to share what I find.
The plan is for me to use mspdebug ( MSPDebug ) once I figure out how to get everything I need correctly built for the pi.
I'll post more info as I have it.
I made some progress yesterday, I managed to build the libmsp430 library on my Raspberry pi, took me most of the day as I'm a Windows/DOS person rather than linux.
The info I used is mostly here: https://e2e.ti.com/support/microcontrollers/msp430/f/msp-low-power-microcontroller-forum/836999/msp430flasher-compiled-to-run-on-arm-architecture
be careful though it doesn't work as documented, many of the directories are wrong and there is an issue with DOS vs linux EoL characters that stumped me for a little while.
Was very happy when I typed make and the build started, 15 mins later I had my compiled library.
Next I need to build mspdebug and then I can start testing, And once I have a working command line method I can test it from Node Red . . .
(yes I know this is very much Node Red ish yet, but bear with me . . . I will get there.)
