Project - Git ssh sync with custom port
I have
  1. installed NodeRed and Gitea on my local Docker Swarn cluster
  2. setup a git key on NodeRed
  3. setup the associated public key on Gitea
  4. setup a remote repository on NodeRed project with this URL: "ssh://git@gitHost:gitPort/gitUser/gitRepository.git"
When I test on the NodeRed container with ssh command, all works fine:
ssh -i ./sshKey -T -p gitPort git@gitHost
But, on NodeRed UI, the connection with remote repository is not possible.
On browser network tab, an error occurs on "/projects/xxxx/branches/remote" request with the following detail:
"git@gitHost: Permission denied (publickey).\r\nfatal: Could not read from remote repository.\n\nPlease make sure you have the correct access rights\nand the repository exists.\n"
I think the porblem occurs because the git server listen on a custom port.
Could you confirm this?
Many thanks for your help.
Hello everybody,
I have found a workaround for this behaviour:
On NodeRed container, I clone the desired Git repository with the "git clone" command on the "/data/projects" folder and then I can sync via ssh protocol on NodeRed UI.
For your information, you can find the complete git command:
git clone ssh://git@gitHost:girPort/gitRepo.git --config core.sshCommand="ssh -i sshKey"
