Hello
I'm developing on an Olimex Olinuxino A20 SBC.
Operating System: Debian GNU/Linux 11 (bullseye)
Kernel: Linux 5.10.105-olimex
Architecture: arm
Installed Node-red with the raspberry pi script
From the node-red start I get this info about what software I'm using
Welcome to Node-RED
24 Nov 11:01:28 - [info] Node-RED version: v3.0.2
24 Nov 11:01:28 - [info] Node.js version: v16.18.1
24 Nov 11:01:28 - [info] Linux 5.10.105-olimex arm LE
24 Nov 11:01:33 - [info] Loading palette nodes
24 Nov 11:01:41 - [info] Dashboard version 3.2.3 started at /ui
24 Nov 11:01:42 - [info] Settings file : /home/mauricio/.node-red/settings.js
24 Nov 11:01:42 - [info] Context store : 'default' [module=memory]
24 Nov 11:01:42 - [info] User directory : /home/mauricio/.node-red
Node-red GUI is working fine, I can install modules using Manage palette tool
When I try to install a git clone of a module using cli
~/.node-red$ npm i ~/.dev-js/node-red-contrib-johnny5/
The module get installed, I can see symlink in ~/.node-red/node_modules/
node-red-contrib-johnny5 -> ../../.dev-js/node-red-contrib-johnny5
But no Johnny5 nodes on the Node-red GUI
What am I doing wrong ? What's the propper way to install nodes using npm ?
Hi @mauricio
If installing nodes in this manner, are you restarting node red after? as you will need to do so..
Thank you Marcus, yes I did restart in my first attempt
~/.node-red$ node-red restart
And the results were that
Now, just now, I did npm pack on the git clone directory of the node, and use the Node-red GUI to install the .tgz file, it install the module and I get Nodes Johnny5 available
Although this work, I'd like to know the proper way to install with npm, or if my installation is failing
~/.node-red$ npm i ~/.dev-js/node-red-contrib-johnny5/ should be fine
(as long as the node itself is of course
I wonder if this is a permissions problem.
Node RED running under a daemon user, and your account installing the node causing ownership / permission problems on the folder/symlink.
given the UI can load the module (even as an upload) might be related to permission problems.
There was a thread a while ago around the same problem, but for the life of me - can't find it.
the command is just one "word" node-red-restart (or) node-red-reload
no space between node-red and restart.... otherwise you are just running node-red with a flow file called restart (which will probably be blank
Awesome !! it works !! That's it !
Thank you
Thank you both
