Q: RE: node-red-contrib-play-audio >> voices
I decided it was time to update my rpi4 (rev B) Home Controller from Bookworm to Debian Trixie (13). For full disclosure I read it is a challenge to upgrade Bookworm to Trixie, best to start from scratch, so I did on a separate pi (leaving my Home Controller and the 2.6Mb flow file running) and used raspberry-pi imager on a new (Sandisk Ultra 64Gb) SD card. Using the port (custom) version of Trixie as recommended seemed to cause me odd challenges so I opted on the 2nd run to choose Raspberry Pi OS (other) and chose Raspberry Pi OS Full (64bit) since I had lots of disk. Interestingly I find this Full version actually seems to run generally quicker (certainly loads the web browser, NR editor and file mgr quicker). There are however lots of apps on this new Home Controller card I'll never use as it has but one purpose.
Any how, getting to the point, everything is working as expected however I have one issue to resolve. On my (dashboard v1) pages I have buttons one can select that "teach" (speak in the browser) about what that column of buttons or items do or indicates. I use node-red-contrib-play-audio for this.
My challenge is that it isn't working because when I try to select the voice to use there is nothing there, no voices. Can anyone suggest how I might fix this? (install proper voices in Deb Trixie)
TIA
Which browser are you using for the Node-RED editor, and is that browser running on the new Pi or on another computer?
OH, good question!
Firefox, running on the same computer as NR (rpi4). It does work when I use my laptop Firefox and access the Dashboard on the local net.
(Not what you want to hear, but.....) :wink:
I am sticking with Buster at my end.
But I do something like what you are doing but do it differently.
I use the exec node and use something like omxplayer and send it the msg.payload.
That works.
Just saying.
Sorry for delayed response, had to go out the rest of the day.
Thanks for the replies and suggestions.
I may yet end up sticking with Bookworm (12), we'll see. What I was most after was getting pi connect set up on my headless NR machine. I've been frustrated trying to make it work on Bookworm, just keeps giving errors I can't figure out how to fix.
Doesn't omxplayer send audio to the RCA jack on the pi? I was looking for audio played in the active browser, wherever (and who ever) it was.
To be honest, I am not sure.
I am sure there are tweaks to control which output it uses.
Just did a quick bit of checking and it seems you can.
omxplayer -o hdmi video.mp4
Thanks, it is solved. The browser of the device being used is where the voices need to reside. Good job by Rei_Kurosawa in tweaking me to that. We can get so focused on something and forget the obvious lol.
Now I gotta figure out why FireFox talks so darn fast (robotic). Sigh .....
Well, good to hear it is now all good.
:slight_smile:
