Query IP address from url
can you finally explain this expression: what means -8..-5 ?
Did you ask? I missed that.
I believe i did say in my brief post
So the [[index..index]] slices the array from -8 to -5. The minus counts from end.
Just for info, [[1,4,6]] would select index 1,4,6
thank you, no I did not ask before.
I think it is finished:
flows.json (8.6 KB)
1: IP check of Raspberry / VM
2: IP check of NAS (with other IPv6 interface identifier) and other dynv6 record.
the dynv6 api is not able to update the IPv6 by getting a new previx / mac address remains.
I changed the kind of update:
dynv6.json (6.7 KB)
only the previx will be updated.
In dynv6 you must first add your record -> typ AAAA -> Data: your host address for example: ::dea6:32ff:fe62:1cd2
MAC Address doesn´t work !
it must be of course EUI64 host address
