Have installed via Pallette and also tried npm on Debian Trixie OS.
after install and node-red resstart no system information icon is seen in left ui toolbar ?
Log shows no issue or clue.
Same issue. Update to v1.0.2 and still nothing in the nodes list (shows in palette as installed)
make sure to tag the author so he gets notification of this issue.
@ralphwetzel
What version of NR and node.js are you running?
When you start NR is there anything showing in the start up log?
adrian@debian:~/.node-red$ node-red
31 Dec 09:48:43 - [info]
31 Dec 09:48:43 - [info] Node-RED version: v3.1.3
31 Dec 09:48:43 - [info] Node.js version: v18.18.1
31 Dec 09:48:43 - [info] Linux 5.19.0-2-amd64 x64 LE
31 Dec 09:48:43 - [info] Loading palette nodes
31 Dec 09:48:44 - [info] Dashboard version 3.6.2 started at /ui
31 Dec 09:48:44 - [info] Settings file : /home/adrian/.node-red/settings.js
31 Dec 09:48:44 - [info] Context store : 'default' [module=memory]
31 Dec 09:48:44 - [info] User directory : /home/adrian/.node-red
31 Dec 09:48:44 - [warn] Projects disabled : editorTheme.projects.enabled=false
31 Dec 09:48:44 - [info] Flows file : /home/adrian/.node-red/SPE_Linear_V1.10PC.json
31 Dec 09:48:44 - [info] Server now running at http://127.0.0.1:1880/
your credentials.
31 Dec 09:48:44 - [info] Starting flows
No issues in log hereon
in /home/adrian/.node-red/node_modules/
Happens in 2 instances of Node-RED, both 3.1.3, both with node.js 18. (One instance on a Pi the other on a VM running Debian).
@meeki007, thank you for that, should have done it myself.
nodejs v 20.5 and later tried, made no differrence here, however I need v18 for a websocket flow to work properly re connection.
Thank you for this report.
Can you spot any issues in the console of your browser?
Ralph, No issues shown in browser console. Just node is missing friom Function list.
Please try Debian Trixie on a amd 64 PC please ?
I don't have a PC so that will not be possible, sorry
npx works fine ;
adrian@debian:~/.node-red$ /usr/bin/npx systeminformation info
โโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโ
โ SYSTEMINFORMATION Version: 5.21.22 โ
Operating System:
Platform : linux
Distro : Debian GNU/Linux
Release : unknown
Codename : trixie
Kernel : 5.19.0-2-amd64
Arch : x64
Hostname : debian
Codepage : UTF-8
Build :
System:
Manufacturer : Dell Inc.
Model : OptiPlex 9020
Version : 01
Virtual :
CPU:
Manufacturer : Intel
Brand : Coreโข i5-4570
Family : 6
Model : 60
Stepping : 3
Speed : 3.2
Cores : 4
PhysicalCores : 4
PerformanceCores : 4
EfficiencyCores :
Processors : 1
Socket :
If the node states to be installed in the palette manager, please try to import the provided example flow.
What's happening then?
What is the browser, you're seeing this effect in?
What version?
Chrome logo
Google Chrome
Version 120.0.6099.129 (Official Build) (64-bit)
That's good news.
In that case there must be an issue report either in the console of the browser or in the log of the runtime. Would be great if you could spot it...
Can you show us what you see in Manage Palette please?
