Readme is missing on flows.nodered.org
Hallo,
for my node https://github.com/Hypnos3/node-red-contrib-cast
there is a readme displayed at github, at npm:
but not at
I have republished the node at npm and now the readme is visible again.
What could be the reason for?
Thank you
Because sometimes the metadata we get from NPM fails to provide the README and the only solution is to publish a new version to get NPM to refresh its metadata.
Thank you for the explanation.
I just noticed this again with the xterm package, even though npmjs shows the readme.
I finally figured out the reason (I had this with my packages), it comes the missing readme data in registry.npmjs.com, e.g. (at time of writing) xterm:
I don't exactly know what npm publish does but it definitely adds that to the manifest before sending to npmjs.com. I use libnpmpublish directly and had to explicitly add the readme data to the manifest before sending (I guess it's a bit of a silly assumption to make that npmjs.com could just add the data since they seem to have identified the readme file):
const libpub = require('libnpmpublish');
let rdme = msg.contents.filter((d) => {
    return d.name == "README.md"
})[0];
if ( rdme ) {
    manifest["readmeFilename"] = "README.md";
    manifest["readme"] = rdme.contents;
libpub.publish(
    manifest, tarball, opts
).then((data) => {
I think that npm have always been clear that only the npm cli should be used for interactions and anything else might not work or might stop working. It is certainly a PITA but I tend to stick to that and use Gulp scripts with the execa extension.
I'm just going through all modules and there seems to be no clear reasons for readmes missing. Older packages (i.e. last published approx. 2 years or longer) have no readme or readmeFilename value yet have a readme content @ flows.nodered.org. I assume npmjs.com changed something about two years ago.
Also what I also discovered that there are a small number of packages (between 50 and 100) that are still listed in the catalogue json but which have been unpublished @ npmjs.com, i.e., there is no package.tgz to install.
All is included in the analytics flow for the catalogue json.
If ONLY someone would go through the flows site and analyse the thing .... oh, wait!
:wink:
Turns out that 92 packages have been unpublished:
node-red-contrib-test-skill (DLYr: 10) reg
red-contrib-meutestedonodered-lower-case (DLYr: 93) reg
node-red-ilvo-redis-get (DLYr: -1) reg
node-red-ilvo-parse-config (DLYr: -1) reg
apconic-node-red-tcp-connection (DLYr: -1) reg
apconic-string-parser (DLYr: -1) reg
integrator-package-test (DLYr: -1) reg
node-red-contrib-cowsay0912 (DLYr: -1) reg
datasource1 (DLYr: -1) reg
node-red-tpro-random-data (DLYr: -1) reg
get-nvisual-token (DLYr: -1) reg
node-red-contrib-environmental-data-simulator (DLYr: -1) reg
tillit-node-red (DLYr: -1) reg
node-red-contrib-tcube (DLYr: -1) reg
node-red-contrib-cyblion-edge (DLYr: -1) reg
node-red-contrib-twitter-retweet (DLYr: -1) reg
node-red-contrib-home-assistant-discovery (DLYr: -1) reg
@tesd/node-red-contrib-powerschool (DLYr: -1) reg
404 Response
red-contrib-generator (DLYr: -1) reg
node-red-contrib-send-form-v4 (DLYr: -1) reg
node-red-contrib-mymiio-server (DLYr: -1) reg
node-red-miio-local (DLYr: -1) reg
node-red-contrib-mclient3 (DLYr: -1) reg
node-red-contrib-mclient (DLYr: -1) reg
node-red-contrib-mclient-outclient-test (DLYr: -1) reg
node-red-contrib-mcore (DLYr: -1) reg
node-red-contrib-c1as-sf (DLYr: -1) reg
node-red-contrib-re-http-ntlm-req-v2 (DLYr: -1) reg
@node-red-plus/node-red-contrib-wago-cc100 (DLYr: -1) reg
404 Response
red-contrib-mime-generator (DLYr: -1) reg
subflow-emrecan3 (DLYr: -1) reg
node-red-contrib-stackhero-mysql-cred-configure (DLYr: -1) reg
@michaelbeljaars/node-red-contrib-grove-base-hat-dtam (DLYr: -1) reg
404 Response
node-red-contrib-neogramm-automation-kit (DLYr: -1) reg
@equans/occupancy (DLYr: -1) reg
404 Response
node-red-contrib-baidu-iot-device (DLYr: -1) reg
@ikologik/node-red-ikologik-api (DLYr: -1) reg
404 Response
node-red-custom-websocket-subscriber-prtyp (DLYr: -1) reg
node-red-contrib-example-lower-case-function (DLYr: -1) reg
node-red-contrib-websocket-subscriber-nohtml (DLYr: -1) reg
node-red-contrib-websocket-header-acknowledge (DLYr: -1) reg
node-red-contrib-meter-lasts (DLYr: -1) reg
node-red-contrib-meter-last (DLYr: -1) reg
node-red-contrib-meter-work (DLYr: -1) reg
node-red-contrib-meters (DLYr: -1) reg
node-red-contrib-interra-temperature (DLYr: -1) reg
node-red-contrib-galaxy-plc (DLYr: -1) reg
node-red-contrib-ffdc-openid (DLYr: -1) reg
node-red-contrib-loop-processing-mac (DLYr: -1) reg
node-red-contrib-postgrestor-mac (DLYr: -1) reg
node-red-contrib-msal-certauth (DLYr: -1) reg
node-red-contrib-face-blur (DLYr: -1) reg
node-red-contrib-serverless-function (DLYr: -1) reg
node-red-contrib-test-qmaker-tt (DLYr: -1) reg
node-red-contrib-observertc (DLYr: -1) reg
node-red-contrib-get-reply-token (DLYr: -1) reg
node-red-flownode-socketio-client (DLYr: -1) reg
node-red-contrib-accellion-custom-generic (DLYr: -1) reg
node-red-contrib-obniz-vn (DLYr: -1) reg
node-red-contrib-timelapse-from-recordings (DLYr: -1) reg
node-red-contrib-kuvork (DLYr: -1) reg
node-red-contrib-twitter-bot6 (DLYr: -1) reg
node-red-contrib-twitter-bot5 (DLYr: -1) reg
node-red-contrib-twitter-bot4 (DLYr: -1) reg
node-red-contrib-squidtester (DLYr: -1) reg
node-red-contrib-lativ (DLYr: -1) reg
nodered-contrib-signal-client-2 (DLYr: -1) reg
node-red-contrib-squid-ease-remote (DLYr: -1) reg
node-red-tankerkoenig (DLYr: -1) reg
node-red-contrib-vhome (DLYr: -1) reg
aaazzz (DLYr: -1) reg
node-red-contrib-squid-volts-amps (DLYr: -1) reg
node-red-contrib-squid-type (DLYr: -1) reg
node-red-contrib-squid-relais (DLYr: -1) reg
node-red-contrib-squid-led-gate (DLYr: -1) reg
node-red-contrib-squid-data (DLYr: -1) reg
node-red-contrib-example2 (DLYr: -1) reg
node-red-contrib-stoptimer3 (DLYr: -1) reg
node-red-node-ui-etable (DLYr: -1) reg
node-red-contrib-accellion-custom-cdr (DLYr: -1) reg
node-red-contrib-pushed (DLYr: -1) reg
red-node-incorta (DLYr: -1) reg
arcelormittal-iot-pdc (DLYr: -1) reg
node-red-contrib-embedded-file (DLYr: -1) reg
node-red-contrib-home-assistant-llat (DLYr: -1) reg
node-red-contrib-ontime4ibm (DLYr: -1) reg
node-red-contrib-wws-example1 (DLYr: -1) reg
node-red-contrib-xiaomi-home (DLYr: 341) reg
node-red-contrib-pegjs (DLYr: -1) reg
node-red-contrib-hyperledger-fabric (DLYr: -1) reg
node-red-contrib-hyperledger (DLYr: -1) reg
node-red-contrib-domino-rest (DLYr: -1) reg
I was surprised not to see @BartButenaers in the top 100, but I think that is due to the assumption that node names start with @ and most of Barts are " node-red-contrib-xxxx"
I had the very same thought, @BartButenaers began later with prefixes. For a complete list of his packages, check out npmjs
All of us "old-timers" have plenty of none namespaced nodes. :older_adult:
Yes that was the convention at the time being...
10 years ago when we started, npm didn't have namespacing. :grinning:
That is quite a euphemism.
The term "later" means in this case: about 4 weeks ago my first prefix ever :roll_eyes:
