Refresh dashboard
hello
I need help.
I'm using msg.ui_control to configure the label for the dropdown node, and every time msg.ui_control changes, I have to refresh the page for the label on the dashboard to update. Does anyone know how to automatically refresh the page when msg.ui_control changes?
I am using Node-RED V4.0.2, Dashboard version 3.6.5, Node.js version: v20.14.0.
From the sidebar help text
Sending a blank tab name "" will refresh the current page. You can also send "+1" for next tab and "-1" for previous tab
So feeding a msg back into the ui_control node should do what you want
But you should be able to update the dropdown without a refresh, can you supply a minimal flow showing the issue.
Thank you, but could you provide me with an example of that?
Read the help text for ui_control node in sidebar and have a go, if you can not work it out, export your effort and i will correct it.
