Hi all,
I having a issue with node-red.
When i log in from Ldap ( a script we built ) everything is ok.
After refreshing the page we loosing all the connection ui and grid of the nodes.
Before(OK):
After (NOK):
I can't see connection nor move them as normal.
I'm using nodered/node-red:minimal as docker container.
Fix only logout and refresh.
check your browser console for errors.
check you node-red console for errors.
This doesn't happen with normal authentication so probably related to the "script you build" for LDAP.
Are you running multiple instances of the container behind a load balancer?
Update***
Hi Steve,
You right i had a ldap authentication error that messed up my all node-red.
Fixed it and thought it was fixed.
Still crashes !!
Hi Nick,
Sometimes i do use few instances, is it a problem with ldap?
