Context
We have several docker/portainer-managed nodered instances on docker VMs (along many other containers). We want/need to update regularly our containers images.
Use case
We want to update minor versions of our nodered images (semi)automatically, to reduce the burden of maintaining updates.
Solution proposed
The introduction of a new registry tag holding only the major version (keeping and ofc) would fit into our existing logic and allow us to easily update for minor changes automatically.
Examples of images with this principle :
- nginx : https...hub.docker.com/layers/library/nginx/1
- traefik : https...hub.docker.com/layers/library/traefik/3
To clarify, what this proposal would do is to add docker image tags with minor/patch versionning stripped out (existing ones) for exemple : 5, 5-24-minimal, 5-24, etc
I actually made an issue first No registry image tag for major versions · Issue #525 · node-red/node-red-docker but I was suggested to discuss it here before, i also have the PR ready Pull Request #526
