Removing node-red-contrib-tts-ultimate?
I've installed node-red-contrib-tts-ultimate, however I realised that it requires SONOS. My bad.
However it doesn't give me the option to remove from the pallet as the ttsultimate-config is in use and I can't find any way to now get rid of it. Does anyone have any ideas?
Go to the right sidebar. There you can find a tab with all your configuration nodes. You can delete the configuration from there. It even shows you unused configuration nodes.
Johannes
PS:
If your looking for offline tts have a look at node-red-contrib-pico2wave (disclaimer, im the maintainer)
Thank you.
I've only started using Node-Red today. I still have a lot to learn. :slight_smile:
