Renaming the custom node
Hello, I have created a custom node and gave it a name. I want to change the name now but every time i try to do it gives me back an error that my node is missing. I know how to change the name once i put it in the pallet. I want to change the name in the sidebar.
If you rename a node type you will need to manually update any instances of that node you have in your flows, otherwise it will complain that it can no longer find that type.
