Request to remove deprecated Zenitel Node-RED nodes from Flow Library
I would like to request the removal of the following nodes from the Node-RED Flow Library:
  • node-red-contrib-zenitel-wamp-auth
  • node-red-contrib-zenitel-opcua
Both nodes were originally published by Erik Mortensen as part of early experimental integrations with Zenitel Connect Pro .
Erik has since retired and these nodes are no longer maintained . I was later added as a maintainer of node-red-contrib-zenitel-wamp-auth , but the project itself is deprecated and should no longer be listed in the Flow Library to avoid confusion for users.
I attempted to link my npm account to the Flow Library in order to manage or remove the entries myself, but the verification process fails when trying to authenticate with npm tokens.
Because of this, I am unable to manage the listings directly.
Could a maintainer please remove these two nodes from the Flow Library?
Thank you for your help.
Best regards,
Toni Gregov
Hi @ToniGregovZenitel
I have removed those two modules from the library.
