RequestError: EPROTO wrong signature type:ssl/t1_lib.c
I tried to set up my first HTTP Request Node.
The assignment is (or should be) rather simple. It should GET this URL.
https://klanten.bizzsms.nl/api/send?username=SOMEUSER&code=TEST&text=TESTNODERED&phonenumbers=0032123456&sendertitle=TITLE
If I paste this URL in my browser, I get a valid response. Obviously the URL above is modified to hide some username details, but even then, the response is a valid one "0|1|user not found". Feel free to try it.
However, if I try this via the HTTP request node with the settings below, it just doesn't work:
I am received the following error message:
RequestError: write EPROTO 3801D2F14F7F0000:error:0A000172:SSL routines:tls12_check_peer_sigalg:wrong signature type:ssl/t1_lib.c:1572:
So what am I doing wrong?
I can only report that this appears to work for me both in Browser and Node-RED
0|1|user not found
Version of Node-RED
Version of Node.js
OS and version?
See from CMD/Terminal prompt after node-red-stop|node-red-start
Start Node-RED
Once Node-RED has started, point a browser at http://XX.XX.XX.XX:1880
On Pi Node-RED works better with the Firefox or Chrome browser
Use   node-red-stop                          to stop Node-RED
Use   node-red-start                         to start Node-RED again
Use   node-red-log                           to view the recent log output
Use   sudo systemctl enable nodered.service  to autostart Node-RED at every boot
Use   sudo systemctl disable nodered.service to disable autostart on boot
To find more nodes and example flows - go to http://flows.nodered.org
Starting as a systemd service.
18 Jan 13:32:12 - [info]
Welcome to Node-RED
18 Jan 13:32:12 - [info] Node-RED version: v3.0.2
18 Jan 13:32:12 - [info] Node.js  version: v16.19.0
18 Jan 13:32:12 - [info] Linux 5.15.0-58-generic x64 LE
18 Jan 13:32:12 - [info] Loading palette nodes
This will help people help you. (Beyond this, my knowledge ends....)
EDIT: Are you sure URL is correct in HTTP request?
Did you remember to put https on the front of the URL in node-red?
If it isn't that, it would appear to be a TLS signature incompatibility - are you using an old version of node.js?
Hi both,
Thank you for your help. Node-Red is installed via Home Assistant as an add-on.
I currently run this:
Welcome to Node-RED
18 Jan 16:00:23 - [info] Node-RED version: v3.0.2
18 Jan 16:00:23 - [info] Node.js  version: v18.12.1
18 Jan 16:00:23 - [info] Linux 5.15.80 x64 LE
Add-on: Node-RED
 Flow-based programming for the Internet of Things
 Add-on version: 14.0.1
 You are running the latest version of this add-on.
 System: Home Assistant OS 9.4  (amd64 / qemux86-64)
 Home Assistant Core: 2023.1.5
 Home Assistant Supervisor: 2022.12.1
I'm pretty sure the URL is correct.
If I change HTTPS to HTTP, it is working fine (it returns 0|1|user not found). But it should work with HTTPS as well...
:sigh: . .
No sure how to read your response. Is that a "sigh, why are you using Home Assistant?"? Or am I missing something here?
Sorry, it's just that as soon as HA is involved, things seem to get complicated.
All I can really suggest is trying a stand-alone install of Node-RED and see if it works there.
You are not doing anything wrong. They use TLS1.2 instead of 1.3 and somehow the cipher they use is not compatible with 1.2 I suspect. Browsers tend to ignore these issues. Depending on your local setup, it might/might not work.
If you try this on the commandline, you will receive the same error:
echo | openssl s_client -servername klanten.bizzsms.nl -connect klanten.bizzsms.nl:443
verify return:1
58703D987F000000:error:0A000172:SSL routines:tls12_check_peer_sigalg:wrong signature type:ssl/t1_lib.c:1572:
Forcing the tls version (as the browser indicated):
echo | openssl s_client -tls1_2 -servername klanten.bizzsms.nl -connect klanten.bizzsms.nl:443
No errors.
I don't think there is an option available to add ciphers/force the tls version to the http request node, instead you could use an exec node that performs a curl, like:
curl --tlsv1.2  "https://klanten.bizzsms.nl/api/send?username=SOMEUSER&code=TEST&text=TESTNODERED&phonenumbers=0032123456&sendertitle=TITLE"
Output:
I think there is a way to set this up in a openssl config file, but never tried this.
That works! Thanks for the workaround!
