Rf remote with 4 buttons connected to a sonoff rfbridge flashed with tasmota
Hi I am new to node-red, I made a flow to my 4-button remote and I want to switch a light on and off with button A, the flow works but it also works when I press button BCD, so it does not listen to the data message it listens to all messages on the topic, there is only 1 topic on the tasmota rfbridge.
I hope someone can help me?
I will try to copy my flow in this post.
[{"id":"168759eedd4a9359","type":"tab","label":"Flow 1","disabled":false,"info":"","env":[]},{"id":"80aceca419e31527","type":"debug","z":"168759eedd4a9359","name":"debug 1","active":true,"tosidebar":true,"console":true,"tostatus":true,"complete":"true","targetType":"full","statusVal":"payload","statusType":"auto","x":950,"y":200,"wires":[]},{"id":"b02a204edfd5dd7e","type":"ha-device","z":"168759eedd4a9359","name":"Toggle couch","server":"70d8ebe0668c351d","version":0,"debugenabled":false,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"inputs":1,"deviceType":"action","device":"19d23a6076a00ab80e76bdae43dfc56b","event":{"type":"toggle","device_id":"19d23a6076a00ab80e76bdae43dfc56b","entity_id":"switch.couch_lights","domain":"switch","metadata":{"secondary":false}},"capabilities":[],"outputProperties":[],"x":570,"y":340,"wires":[["80aceca419e31527","cd7688305081a332"]]},{"id":"0ee97d7a30594206","type":"mqtt in","z":"168759eedd4a9359","name":"","topic":"tele/tasmota_C37EAE/RESULT","qos":"2","datatype":"auto-detect","broker":"e62833f54f74b756","nl":false,"rap":false,"inputs":0,"x":150,"y":340,"wires":[["f2e8dceacecaefd3"]]},{"id":"f2e8dceacecaefd3","type":"json","z":"168759eedd4a9359","name":"","property":"payload","action":"","pretty":false,"x":350,"y":340,"wires":[["b02a204edfd5dd7e"]]},{"id":"0fe91de3161eaf0c","type":"inject","z":"168759eedd4a9359","name":"remote button B 85F5E8","props":[{"p":"payload.RfReceived.Data","v":"85F5E8","vt":"str"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":350,"y":120,"wires":[[]]},{"id":"07c88e2ecf727dd6","type":"inject","z":"168759eedd4a9359","name":"remote button A 85F5E4","props":[{"p":"payload.RfReceived.Data","v":"85F5E4","vt":"str"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":350,"y":60,"wires":[["b02a204edfd5dd7e"]]},{"id":"19fe3067186b7655","type":"inject","z":"168759eedd4a9359","name":"remote button C 85F5E1","props":[{"p":"payload.RfReceived.Data","v":"85F5E1","vt":"str"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":350,"y":180,"wires":[[]]},{"id":"295265e8b5b80380","type":"inject","z":"168759eedd4a9359","name":"remote button D 85F5E2","props":[{"p":"payload.RfReceived.Data","v":"85F5E2","vt":"str"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":350,"y":240,"wires":[[]]},{"id":"cd7688305081a332","type":"mqtt out","z":"168759eedd4a9359","name":"","topic":"cmnd/tasmota_C37EAE/RfKey1 payload: 6","qos":"","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"e62833f54f74b756","x":870,"y":340,"wires":[]},{"id":"70d8ebe0668c351d","type":"server","name":"Home Assistant","version":5,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":"30","areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":": ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"default","statusTimeFormat":"h:m","enableGlobalContextStore":false},{"id":"e62833f54f74b756","type":"mqtt-broker","name":"","broker":"192.168.178.249","port":"1883","clientid":"","autoConnect":true,"usetls":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"userProps":"","sessionExpiry":""}]
[edited by moderator]
  • edit your post, use the </> symbol to post code.
  • your flow is using home assistant, people here cannot replicate your home/setup
  • create a flow with some dummy data that people can use to "emulate" your setup:
copy the input/output data from the debug nodes and your expected results.
Use a debug node set to complete message object, to see what messages come from Tasmota when you press each button.
try looking at - msg.payload.RfReceived.Data
Then use a switch node to route only the messages that you want.
